Old 03-18-2008, 05:35 PM
Brigzee's Avatar
Brigzee Brigzee is offline
Default Two Piece Driveline Angles
How is the proper way to set up a two piece driveline. I am getting some vibration in my 62 Bubble. With the LS1 and T56 the trans is 3-4 degrees down. What should I set the pinion at, does the center bearing support play a factor.
Old 03-18-2008, 06:00 PM
Fluid Power's Avatar
Brig,
Here you go, tons of info on this site.
http://www.vibratesoftware.com/html_...Specifications
