Old 03-20-2008, 08:40 PM
Blown353 Blown353 is offline
Default FS: Baer Track brakes and Global West A-Body upper arms
I have the following up for sale. Both are used and have about 10K miles on them but are in excellent condition.
First up: Baer "Track" brakes, PBR Calipers, 13" slotted / crossdrilled / slotted / zinc washed 2-piece rotors, Goodridge stainless hoses. Pads are from Baer and have about 50% of the life left. Baer aluminum hubs with the big outer bearing, 5 x 4.75 bolt pattern. These brakes are on B-body spindles (large outer bearing); they will fit on a 64-72 A-body if you change the tie rod, lower balljoint, and use a shorter upper control arm (what I just removed them from.) They are a direct bolt on for 77-96 B-body cars, 73-77 A-body cars, and 70-81 F-body. Asking $1100 + actual shipping costs, or if you're local we can meet up.
Next up: Global West CNR-42A upper control arms. Global West's top of the line control arm with del-a-lum bushings. These are for a 64-72 A-body with a B-body spindle swap. Asking $425 shipped.
I'm located in the CA Central Valley but will ship. PM me if interested.
1969 Chevelle
Old 03-22-2008, 04:51 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
just an fyi, and unsure about camaros but assume the same, roughly 1980-up firebirds use a different spindle, hub, ball joint.
i have the 2-piece 13" baers on my 2nd gen; they look and work great.
Old 04-01-2008, 11:57 AM
Sale pending on GW arms... brakes are still available.
1969 Chevelle
