Old 03-21-2008, 01:30 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Advise about Pedals, Sought from Real Drivers!
To All Experienced Drivers?
1969 Camaro to be Driven on the Street and Road Race Course. Want to learn and drive car correctly.
What pedals would you choose or do you like for this application?
Brand and Why?
Tilton?
Wilwood?
Other Company?
Location of Mount and Why?
Floor Mount
Firewall Mount?
Type of "Kit/Package" and Why?
2 Pedal "Kit"
3 Pedal "Kits"
Would like to have some adjustability so, "Blipping" Throttle while Braking can be done correctly as to become natural eventually.
Please consider performance over price, then best bang for the buck.
This seems to be a topic not spoken about very often as far as performance pedals. Seems to be discussed in terms of Pedal covers more often.
If you have driven both for enough time to really Understand the Pros and Cons of Each, all the Better.
(Ask Correct Questions, Build Car Once!)
I really appreciate you input in advance,
Best Regards,
Ty O'Neal
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 03-21-2008, 04:11 AM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
I have some of the same questions dancing in my head????????????? Input would be greatly appreciated.
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 03-21-2008, 12:21 PM
James OLC's Avatar
There are alot of considerations that you have to take into account with pedal boxes or assemblies and like anything else your decision will have potential consequences that may steer you away from one layout or another. Based upon my experience (I have a Tilton 900-Series firewall mount pedal assembly in the OLC '67) I can offer the following thoughts and observations:
Manufacturers - top 3:
  • Tilton
  • AP Racing
  • Brembo
In all reality the three are probably tied as they all offer a top shelf system but I ranked them that way because (a) I have seen and used the Tilton system, (b) the AP pedal box is a proven product (primarily overseas) but I had very little success sourcing in in NA, and (c) the Brembo unit is quite new and I have not had an opportunity to see it myself. These are also probably the three most expensive offerings on the market but you did say performance over price and these three are used in top tier motorsports around the world.
Location and Mount
There are definately pro's and con's to both layouts, what I found was:
Floor Mount
Pros:
  • More commonly available as a 3-pedal assembly
  • More flexibility with reservoir mounting locations
  • Easier overall plumbing
Cons:
  • Camaro toe panel forces choice between fabrication and seat mount location
  • Your pedals are where they are and you have to be comfortable with them
  • You are going to have plumbing in the car and will need to consider routing outside of the car as well
  • Need to think about steering column
Firewall Mount
Pros:
  • Pedals will be located in essentially stock location
  • Can use stock gas pedal or drive by wire (with 2-pedal boxes)
  • You have a little more flexibility on location and layout
  • Stock seating location is maintained
Cons:
  • More commonly 2-pedal vs 3-pedal
  • Can't use stock steering column (can be overcome - thank you Ididit)
  • Reservoir mounting and plumbing requires more thought
  • Drivers side valve cover (can be overcome)
  • Will require reinforcement of firewall and (recommended) tie to cage
2-Pedal vs 3-Pedal
Entirely up to you but you may be limited depending on your choice of firewall or floor mount. One advantage of the 2-pedal box is it allows you more choices with your gas pedal and location of the pedals themselves. On the Tilton assembly you can move the pedal pads relative to the arms to fine tune for fat feet. In my case I am using a locar gas pedal and am having a custom pad machined to optimum heel toe comfort. You could also buy a mono heel toe pedal cover.
One other consideration that you could have (and this would depend on you dash/gauge layout) would be the use of a through firewall or reverse overhung design with a firewall mound)
Thats knid of a quick summary. If you have any specific quesions or want more details just let me know.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 03-21-2008, 01:50 PM
rwhite692's Avatar
Stock.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 03-22-2008, 01:49 AM
tyoneal's Avatar
Originally Posted by rwhite692 View Post
Stock.
rwhite692:
Why stock over the other offerings available?
Do the Stock Pedals offer correct foot positioning so proper foot usage can be accomplished? (aka You are in a position to learn and drive correctly as recommended by Driving Teachers)
Have you had the opportunity to spend a lot of time using these other systems?
I am interested in your reasoning.
Thanks for chiming in.
Regards,
Ty O'Neal
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-22-2008, 02:24 AM
tyoneal's Avatar
James:
Thanks a lot for offering your advice and experience with these other pedal choices. I'll answer/ask within your last post.
There are a a lot of considerations that you have to take into account with pedal boxes or assemblies and like anything else your decision will have potential consequences that may steer you away from one layout or another. Based upon my experience (I have a Tilton 900-Series firewall mount pedal assembly in the OLC '67) I can offer the following thoughts and observations:
Tilton
AP Racing
Brembo
Location and Mount
Floor Mount
Pros:
Cons:
Firewall Mount
Pros:
Cons:
2-Pedal vs 3-Pedal
James:
Thanks for your offer. Before spending the money on your set up, where did you get your experience with the after-market pedals? (Driving Schools?
Have the Floors of your Camaro been modified? If so, were they change for the pedals or were the pedals chosen for the existing space that came originally with the car.
How did you do your research? Did you have anyone drive your car and make suggestions based on your car?
It's late, I'll post some more soon if I can think of something relevant,
Thanks again,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-22-2008, 09:12 AM
James OLC's Avatar
Originally Posted by tyoneal View Post
Before spending the money on your set up, where did you get your experience with the after-market pedals? (Driving Schools?)
I have been building race cars for quite a while and have had the opportunity to try lots of different arrangements in my cars and customer cars as well. I had the opportunity to see the Tilton assembly and speak to their engineers at Sema 2 years ago and that really solidified my decision.
lol. Yes, the floors in my Camaro have been modified but no, it had nothing to do with the pedals. The pedal assembly fits in the stock(ish) location (As mentioned I am using a Locar has pedal which is in the stock location).
Ty
I made my choice based on engineering, history, feel and suitability for what I was looking for. Research - internet, word of mouth, Sema. As far as having someone else drive my car to tell me what kind of pedals I want...that really wouldn't help me much would it?
James
1969 Camaro - Dusty
Old 03-24-2008, 02:01 PM
tyoneal's Avatar
James:
Thanks a million for the information. Your research sounds very thorough and I appreciate you sharing it with me.
Best Regards,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-24-2008, 02:04 PM
tyoneal's Avatar
Any other recommendations based on experience?
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
