Old 03-24-2008, 11:19 PM
mcfadyen72's Avatar
mcfadyen72 mcfadyen72 is offline
Default 70 chevelle - frnt brake choices?
what's the most affordable way to upgrade the stock disc brakes on this car?
are there any systems of other newer gm cars i could find at a wrecker or is the best way to go is just buy a new set and which ones?
Old 03-25-2008, 12:12 AM
Look in to http://www.kore3.com/ there brackets use c5/c6 brakes or see if you can find brackets online for last gen camaro brakes maybe.
Old 03-25-2008, 12:46 AM
Bulldog68's Avatar
Bulldog68 Bulldog68 is offline
I have a 70 Chevelle and have been researching this topic also... So far, I've found that Kore3 and Touring-Classics have good reputations and usually come in costing less than the comparable Baer kits. I've also heard that some supporting vendors (Frank at Prodigy Customs) offer some good prices on Wilwood packages. Perhaps someone else can comment on personal experiences with any of these kits or vendors...
Based on what I've researched, I can tell you that TC's website is easier to navigate and select the right kit for your car. That said, Kore3 has more options to choose from, including the higher-end stuff like Z06 and Z51 brakes. Both offer basic C5 conversion packages for the Chevelle. I've been eyeing a kit from TC which includes a 13"/12" C5 kit with master, brackets, and brake lines for around $1700. Add $165 for a booster and you're still under $2000 for everything. I tried to price a similar kit through Kore3, but got distracted with all the Z51 and Z06 goodies. Too many variables!
Good luck.
68 Camaro - a pro touring project with no end in sight.
70 Chevelle - the one that gets out of the garage every once in a while.
