Old 03-25-2008, 09:44 AM
68TINCAN 68TINCAN is offline
Default Pilot Bearing For T56 Swap
Hi Everyone,
I Am Installing A Lt1 T56 Behind A 396 Big Block. (2 Piece Rear Seal)
I Contacted Mcleod For Part Number And They Said It Needs An Extended Bearing. I Talked To Centerforce And They Said That It Does Not And I Could Use One For 396 Motor.
Now I Do Not Know What To Use. Can Anyone Shed Some Light On This?
Thanks In Advance!!
Old 03-25-2008, 11:42 AM
If you are using the factory LT1 style T56 bellhousing and clutch setup on your BBC you can use the GM pilot bearing PN 14061685.
Tyler
