Old 03-26-2008, 05:01 AM
bulldog19 bulldog19 is offline
Default powder coating calipers/master cylnder?
Can anyone reccomend a source for powder coating calipers?
Can the master cylinder and proportioning block be powder coated as well?
How difficult is it to dis assemble re-assemble the caliper? I have never done before and don't want to get in over my head.
Thanks for the assistance.
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 03-26-2008, 10:26 AM
Get in touch with Steve Rupp on this one, he's done this before.
Old 03-27-2008, 08:23 PM
Smittys67's Avatar
Smittys67 Smittys67 is offline
Taking calipers apart is pretty easy if your careful. Put a piece of wood in the caliper and use air to blow the pistons out. MAKE SURE YOUR FINGERS ARE OUT OF THE WAY IT HURTS BAD IF YOU PINCH THEM. Use as little air as possible cuz they pop out quick. Remove o-ring and dust seal and the bleeders. Have the powder coat place plug the holes and tape the bores and you will be in good shape. When you get the back tap the bleeder holes and make sure the piston bore does not have a burr on the edge if it does clean it up. Use a little brake fluid to lube up the o-rings anf the pistons and reassemble.
Chris Smith
Smittys Custom Auto
www.smittyscustomauto.com
Purpose Built Cars since 1999
Complete Turn Key Builds Custom Fab and Chassis shop
Dealer for Ridetech, Detroit Speed, Vintage Air, Billet Speacalties, Forgeline, Flamming River, No-Limit, SoffSeal, Wilwood, American Autowire, BeCool, Moser Engineering, MotorState and many more
Old 03-28-2008, 04:42 AM
Thanks for the lead and tips.
John
