Old 03-29-2008, 01:43 PM
deuce_454's Avatar
Default track9 or currie 12 bolt or g-body
i know its been asked a million times.. but im really wondering what to buy.. a currie track9 or a currie 12 bolt for the malibu... im pretty sure that my 29 year old 10 bolt wont take easy to a 500+ hp ls1, and 285 wide soft tires...
the track 9 is nascar cool.. and indestructable... the 12 bolt from currie looks oem, ahd has the same 9 inch ford housing ends as the track9.. so the argument of c-clips is non existent...
so go fro the nascar pedigree track9.. or go with the added efficiency, and oem looks (im not sure what the weight difference is) a 33 spline 12 bolt is propably equally bulletproof
Jake: Hit it.
Old 03-29-2008, 02:09 PM
rallye455 rallye455 is offline
I recently bought a Moser M9 Fabricated housing and it seems to be a decent piece for the money. I got a real good deal on it and added some braces and backbrace myself. I have pics on another thread if your interested.
Old 03-29-2008, 02:59 PM
deuce_454's Avatar
thats basically a 9 inch in a super cool housing... but whats the upside of running that over a track9? wieght?? is it stiffer??
Jake: Hit it.
Old 03-29-2008, 04:23 PM
clill's Avatar
clill clill is offline
I have no comparison comments but Stielow has been using exclusively Currie rears and we are using one in my current Camaro project. They are nice guys and have been great to deal with.
Old 03-29-2008, 07:08 PM
Its stronger...not sure about the weight...it might even be a little cheaper...whats the Currie housing and axles going for?
Old 03-30-2008, 04:54 AM
The budget set up for you is look for a 8.5" rear out of a GN. They can be found for $1000 to $1200, and I have a lot of friends holding that much power. Or is you must, I would do a 12 bolt myself, but that's just my preference.
Frank Serafine
Old 03-30-2008, 09:13 AM
deuce_454's Avatar
hmm, knowing me i would propably rebuild the 8.5 inch just to know that its in perfect working order... c-clip eliminators would be next... the safe bet is propably the 12 bolt.. especially since my bear brakes have ford brackets....
the 12 bolt seems to be alittle cheaper too, its the same price as the 9 inch.. but it doesnt require a centersection... and id propably go fro am aluminum CS just because it was available....also its 33 splines instead fo 31
Jake: Hit it.
Old 03-30-2008, 09:33 AM
I can set you up with a Moser. Send it with the wheels
Frank Serafine
Old 03-30-2008, 10:45 AM
Who sells that lower coil over bracket to use coil overs in the stock lower shock mount?
Old 03-30-2008, 11:07 AM
That is a G Bar 4 link and our rear. The brackets are part of the rear.
Frank Serafine
