Old 03-29-2008, 06:21 PM
bucks69 bucks69 is offline
Default pics needed of a 69 Camaro rocker panel (inner)
Hey Guys I need a few pics of the inner rocker panel such as if it is off looking at the inside peice that goes against the outer, also, I need a pic of the outer from the inside after the inner is pulled off. I searched the previous threads but didnt find what I needed.. TIA
Old 03-31-2008, 04:46 AM
Overkill's Avatar
Overkill Overkill is offline
Not sure if these will work for you or not, but here are the pictures I took when I replaced my passenger rocker panel on my '69 Camaro.
Don't know if this helps you with the inside look of the outer rocker
You can see the inner brace that I had to cut out and install in the new rocker in this picture.
Getting all the old metal out of the front was a pain in the neck.
This is inside the car and shows you what I had to drill out to get the rocker and inner brace out.
The picture above and the one below is the inside brace on the rear of the rocker panel. I had to cut it out of the car and put it in the new rocker.
I thought I had one of the inside of the outer rocker with the brace welded in, but I can't seem to locate it on my website. Hopefully these help you out some.
Michael
CamaroHeaven.org
Old 03-31-2008, 08:10 AM
That is exactly what I needed, thanks a bunch. I appreciate the help
