Old 03-30-2008, 12:40 PM
Project_Gotham Project_Gotham is offline
Default LS2 402- Carb vs. EFI
402 LS2 carb vs. EFI
Going with a 402 Ls2- 6 speed. I have a set of RHS 210cc heads.
Going carburated would be easier since I do not have harness for this set up. What are the advantages/disadvantages going with the Edelbrock system rather than EFI.
Thanks!
Marcus
--Mark Stielow Wannabe--
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
2014 Chevrolet SS Sedan
Old 04-01-2008, 05:53 AM
Stang's Bane Stang's Bane is offline
I haven't done any research for the hard numbers for this, but I would think that all of the hardware required to convert to carb would be almost as much as a custom wiring harness, not to mention a second hand one out of a f-body or something.
The drivability is going to be better with the EFI.
Old 04-01-2008, 09:52 AM
Nate_ERC's Avatar
Nate_ERC Nate_ERC is offline
Unless you REALLY have a personal preference for a carb setup, I don't see any reason to take the motor backwards in technology. It's about the same amount of work either way.
www.eckertsrodandcustom.com
Old 04-01-2008, 05:15 PM
Pantera EFI Pantera EFI is offline
Default IGN-8 LS-X Ignition
There are many reasons to do both, so we do. The ECU-IGN-8-(x), is a perfect ignition for a carb'd LS engine.
I fit the GMPP "spider" intake (in-stock). This intake is GOOD for high HP, BUT short on low end torque.
Check-out "WaterThunder.com" as they use the "combo" to chase Gator's
Lance
Old 04-01-2008, 08:57 PM
I have been talking to Texas speed and said that it's mainly personal prefrence but said that carb set up actually flow alot more.
1968 Camaro SS
1969 Camaro SS
1969 Camaro LS7
