Old 03-05-2008, 02:26 AM
deuce_454's Avatar
i just bought a "how to modify your harness" book, but its cery nice to know i can order a working one when i screw somthing up LOL
Jake: Hit it.
Old 04-04-2008, 07:03 PM
radrambler's Avatar
Default reasonable new ls1 harness source
guys
im alwasys hunting on ebay for car stuff i need
found and purchased a NEW LS1 ENGINE HARNESS from a company called
WWW.TECHRODS.COM ..THE PRICE IS THE MOST REASONABLE IVE SEEN..
i know a bunch of us are using lsx motors and i just wanted to pass on the info for guys looking for a realistic price and i did talk with shane to make sure he can provide customer service... i am satisfied..and saved hundreds..
oh , and he shipped quick also...
hope this helps
radrambler
Old 04-05-2008, 06:19 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Do you have any picks? do they look as good as speartech?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 04-06-2008, 10:04 AM
radrambler's Avatar
Default look?
well
id dont have anything to compare the harness against.
im happy....and it wasnt 700 plus dollars....
radrambler
Old 04-06-2008, 06:56 PM
bigtyme1's Avatar
Radrambler, I just got off the with Shane, seams like a good guy. I need to work a few things out first. Funny thing, when I hit redial the answer machine said Jeff.
69 RS Ragtop
[email protected]
Old 04-07-2008, 05:48 AM
radrambler's Avatar
Default ok
maybe roomies?
he seems great to deal with
radrambler
Old 05-05-2008, 06:24 PM
bigtyme1's Avatar
Originally Posted by radrambler View Post
guys
hope this helps
radrambler
What kind of information do I need to give him when ordering?
69 RS Ragtop
[email protected]
Old 03-08-2011, 06:01 PM
geberhard's Avatar
geberhard geberhard is offline
Bringing this thread back from the depths, anyone has experience with them and their products?
Old 03-08-2011, 06:14 PM
LS1NOVA LS1NOVA is offline
For those wanting to save LOTS of money but have the time, you can do your own harness. This is what I have done a couple times now.
Buy a low mile 99-04 Cable TB truck harness for $50
Buy a pack of 50 each of 18 and 20ga pcm terminals from Mouser
Buy a crimper for MAC tools for $20
Use Lt1swap.com for fuse block details and wiring diagrams $20
Cut all the pcm wires off and seperate all the individual sensor circuits
Route the wires how you like and terminate at the pcm
Cover with flexbraid from Cabletiesandmore $20
The truck wires are plenty long to route the pcm away from the engine and you end up with about $120 in it.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 03-08-2011, 09:30 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
The wires in a truck harness are only plenty long if you’re keeping the pcm in the engine bay. I started with a truck harness on my build. I wanted to put the pcm in the car behind the glove box. From the factory the truck pcm is located on the drivers side inner fender. I removed all terminals from the pcm and routed wires to the center of the engine behind the intake. I planned on routing the harness through the trans tunnel. After gathering all the wires I realized about half of them would be too short for the location I mounted my pcm. I later modded a stock fbody harness for a friends swap and I think that harness would have worked great in my swap as well. The fbody harness is harder to find and more expensive. I'm all for using the cheap and available truck harness. All I’m saying is consider where you want to mount the pcm.
I ended up making a new harness from scratch. I work for easyperformance.com and we build a LS1/BS3 piggyback harness for speed Inc. I figured with using my truck harness and the speed Inc harness as a template building my own would be no problem. After putting at least 30 hrs into my harness I think techrods price is a steal. Granted my harness has a lot of little extras in it, but it was still a ton of work.
Jason Mitchell
1971 Camaro 416 LT1 Project
