Old 04-08-2008, 06:47 PM
latzoo latzoo is offline
Default 67 RS Grill
I am intend to install a RS front end on my 67 LS1 Camaro. I have heard tha it is better to use a 68 kit due to the vaccum being cheaper easy to use. I am confused. Help me....
Old 04-08-2008, 07:24 PM
Bulldog68's Avatar
Bulldog68 Bulldog68 is offline
How about the electric kit? Sounds easier than messing with the vacuum stuff...
http://www.detroitspeed.com/productp...t_kit_prod.htm
68 Camaro - a pro touring project with no end in sight.
70 Chevelle - the one that gets out of the garage every once in a while.
Old 04-08-2008, 08:35 PM
class67's Avatar
class67 class67 is offline
Electric is much easier and less problematic
Steve
67 Camaro RS
66 Chevelle (in progress)
Old 04-08-2008, 09:27 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Use DSE and you will be happy. Don't and you will wish you had. Just do it right the first time. Also take your time! That stuff is flimsy, soft and ruined in a heart beat if your not careful.
Have fun!
Curtis
Old 04-08-2008, 10:28 PM
Electric is the way. You would use 68 stuff and use the DSE kit. Just did it, and have it all down. Also, I like the 68 RS grill with the polished edges better then the 67 grill. I should have most of it in stock.
If you need any help, call
four zero seven 832 1752 8 AM to 10 PM eastern time
Frank Serafine
