Old 07-30-2005, 07:24 AM
Twin_Turbo Twin_Turbo is offline
Default custom front susp. nearly complete
Control arm is not completely finished, needs some more grinding and cleaning up here & there.....
sway bar is just mocked up in it's place, will run a splined speedway bar w/ separate arms, this is a stocker.
Old 07-30-2005, 10:18 AM
DCreations DCreations is offline
WoW that is mean looking nice job
Dave
“Tony Tony Tony, I know that your horny, but there’s
somethin bout that Bush ain’t right”
Old 07-30-2005, 10:37 AM
T Bell T Bell is offline
looking great. You wanna build some A-body arms?
Old 07-30-2005, 12:23 PM
Thanks, it's a corvette so the arms only fit that and not even on a stock frame without cutting off the spring pockets and I live in the netherlands so you can guess what shipping costs. There are kits out there (jim meyers racing) but I wanted my coil overs set up like this, close to the ball joint for a closer wheel & spring rate so i had to fab it all myself and I had to move a whole bunch of stuff (I'm going to front steer end take off rack & pinion instead of the stock box / rear steer and the sway bar is mvoed as are some other things, no way this fits w/ a stock radiator setup)
Old 07-30-2005, 04:05 PM
sinned's Avatar
sinned sinned is offline
Looks good...who did your design analysis for the new ball joint pivot points?
Dennis
Old 08-06-2005, 10:55 AM
The lower control arm is dimensionally identical to the original one, the only thing that moves is the spring rate by placing the coil over closer to the balljoint than the original coil spring, the revised geometry is done w/ adjustable upper arms and adjustable upper ball joints.
Old 08-07-2005, 06:32 AM
hotwheels's Avatar
hotwheels hotwheels is offline
awesome job man.........that looks sweet
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 08-22-2005, 10:05 AM
front steering almost complete, need to notch the frame horns and finish modifying the crossmember, the steering shaft setup will be a little tricky but can clear the dry sump pump pulley by just enough.
Last things to do will be hooking up the sway bar w/ heims (replacing it w/ a splined speedway bar & seperate arms)
