Old 04-20-2008, 03:59 PM
deuce_454's Avatar
Default ATS spindles and wheel studs
Ok i just got the malibu in the road (i have ATS spindles with the upgradedARP 1/2-20 wheel studs, and when ever i corner there is a sound like a CV joint "klonk"-ing... i found after much experimenting and crawling arround that its is the back of the studs (the mushroom part that is on the back of the mounting flange) is hitting the bolts that are holding the bearing pack into the spindle... what do i do... grind a milimeter of the back of the studs... or is there a problem with the bearings them selves since they can deflect enough so the studs can hit????
Jake: Hit it.
Old 04-20-2008, 04:31 PM
68protouring454's Avatar
more then likely you need to countersink the holes in your rotor, whats happening is the knurl part of the 1/2 stud sticks out beyond the wheel flange, so when you tighten the wheel it pushes the stud out just alittle, causing it to do what your talking about. if you jack the car up the wheel will feel loose.
this is common anytime you install 1/2 studs no matter front or rear end, and only some rotors need to be countersunk, some are fine and have no issue.
goodluck
Jake's Rod Shop
Old 04-20-2008, 04:44 PM
deuce_454's Avatar
AWESOME it did look like the studs werent seated all the way... will countersink tomorrow and see what happens! ill post as soon as i get back from the shop tomorrow, thanx again!
Jake: Hit it.
Old 04-20-2008, 07:35 PM
yes, just countersink the back side of the rotors about 3/16 to 1/4 inch and then by hand make sure they seat flat on the flange, also you will need to re-seat the studs, there should be enough grip in them to hold forever still, just countersink the rotor,re-seat the studs, install wheel tq to 100 lbs, if it tq's fine then your good to go.
goodluck
jake
Jake's Rod Shop
Old 04-20-2008, 09:25 PM
796spdbu's Avatar
796spdbu 796spdbu is offline
hey duece,
do you have a build thread on here or pics of the wheels and tires? I want to put 18x9.5" with a 295-35 under the back of my malibu also. What is the back spacing? I would like to see your whole car build if possible.
Thanks,
Greg Tholen
Old 04-21-2008, 10:50 AM
deuce_454's Avatar
Default worked like a chram
i countersunk the holes and reinstalled (the shop that did the assembly had originally installed the rotors and the clonking only presented it self on the drive home)
the whole job took about 30 mins and wholy crap does that thing corner.... i have been pushing the limits alittle in a roundabout not far from my dads place and the long left followed by a right to exit could be executed in a pace that almost sent a new mercedes SL off the road trying to keep up.. and it felt like there was more left in the BU..
so my hat is off to ATS, handling is just plain awesome... ZERO bumpsteer, just tonnes of grab!
with regards to the wheels.. ill post somthing soon.. im mounting 285´s so ill be dinling arround with the wheels shortly
Jake: Hit it.
Old 04-21-2008, 11:23 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
with regards to the wheels.. ill post somthing soon.. im mounting 285īs so ill be dinling arround with the wheels shortly
That's funny! Glad your getting more than you expected...that's always a good thing.
Curtis
Old 05-04-2008, 08:10 PM
malibu795 malibu795 is offline
got a link to ATS's site? i got a 79 malibu
Adam Wildman
99 C3500HD dmax/4l85E
79 malibu wagon 468bbc/ t-56/8.8
U.S. Navy 2000-2008
Old 05-04-2008, 08:27 PM
http://www.t56kit.com/
Jake's Rod Shop
Old 05-04-2008, 08:56 PM
thanks you sir
Adam Wildman
U.S. Navy 2000-2008
