Old 04-20-2008, 09:34 PM
DFAuto DFAuto is offline
Default 67 mustang fastback project
I have a 67 Fastback Project for sale. It is a rolling shell that needs a total restoration. It has been totally media blasted so what you see is what you get. The body is far from perfect but according to my body guy totally workable.
What is included:
-GT500 hood and nose
-Corvette front and rear disc brakes(with correct front hubs)
-Freshly built 9" w/ traction lock and new axles
-front seats(completely restored not just upholstery)
-heavy duty front springs and front and rear sway bars
-rear bumper
-automatic shifter(stock)
-Front crossmember and automatic trans crossmember
-Strut tower braces
-hood latch bracket
-stock upper side vents
-Stock 8" rear end
I also have a freshly built 390cu in FE engine. All of the machine work and assembled of the long was performed by a reputable engine shop and everything was cleaned, checked and refurbished or replaced.
-It includes correct mustang gt heads(three bolt exhaust ports)with mild port job
-forged flat top pistons with moly rings
-ARP rod bolts
-balanced rotating assembly with new balancer and new C6 flexplate
-double roller timing set
-Edelbrock performer RPM intake that has been port matched to ported heads
-Edelbrock Performer rpm cam and lifters
-new push rods
-all new bearings and gaskets
-new oil pump, drive rod and pickup
-stock distributor with accel electronic conversion
-new plug wires
-new cap and rotor
-new thermostat
-holley 750 double pumper
-stock valve covers, oil pan and air cleaner housing
-misc pulleys and a few other things that I can't remember
I am asking 11,000 OBO for this project car. The car has no title but it has been off the road for about 5+ years. Email if you are interested and I will get back to you as soon as possible.
