Old 04-24-2008, 12:46 PM
Default Chris Alston G bars are coming. Pre orders are being accepted!
I got permission today to accept pre orders and feedback for the all new Chris Alston G bar, G Link and G billet triangle 4 link rear suspension kits. The kits are going to come in 3 variations,
The entry level kit and probably most popular kit the G Bar using urethane bushings, steel arm kit that replaces the previous G bar. This kit is probably the most street friendly. Chris Alston says this kit best used in applications under 500HP. The G bar is priced at $1739 with coil over Vari Shocks, add $200 for double adjustable shocks. There is a Air Spring option for a additional $400. There are 2 optional Anti Roll bars for the G bar. Either a sliding link adjustable bar for $359,or a trick splinded-end bar with hot looking aluminum arms for $479
Base G Bar kit with poly bushings
The next level up is the G link using Pivot balls / steel arms and has the added feature of adjustable lower arms. Chris Alston says this kit is probably best for higher horse applications that will be dead hooking at the dragstrip, or applications that can take advantage of added adjustability. The G link is priced at $2049 with coil over Vari Shocks, add $200 for double adjustable shocks. There is a Air Spring option for a additional $450. There are 2 optional Anti Roll bars for the G bar. Either a sliding link adjustable bar for $359, or a trick splinded-end bar with hot looking aluminum arms for $479
G Link with pivot balls and adjustable arms
For the Ultimate in Performance and pure bling, there is the G Billet using Pivot balls and Aluminum I beam. Chris Alston says this kit is suited for street or racing, and looks killer doing it. The G Billet is priced at $2249 with coil over Vari Shocks, add $200 for double adjustable shocks. There is a Air Spring option for a additional $450. There are 2 optional Anti Roll bars for the G bar. Either a sliding link adjustable bar for $359, or a trick splinded-end bar with hot looking aluminum arms for $479
The G Billet with Splined-end sway bar option
Also available are Bolt in Fabricated 9” housings that can be built to any length within reason. Add back bracing and lower sway bar mounts for a truly trick looking bullet proof set up. Axle housing start at $989
Fab 9 housing and Anti Sway
Frank Serafine
Old 05-05-2008, 10:31 AM
copo69 copo69 is offline
well i guess i need to save a few more pennies . with 750 hp i guess i will need option 3 . but then again this car will never have slicks on it or proably be at the track . alstons shop is just down the road from me a few miles.
ok well we will order one of theese for my big block car soon maybe a month or 2. i can save on shipping as they do release parts right out the door at alston.
if you cant smoke the tires at 60 mph your engine needs work !
Old 05-05-2008, 03:31 PM
blissbsm's Avatar
blissbsm blissbsm is offline
Talking
Frank, Email me a price for the set up I need.
Old 05-05-2008, 05:31 PM
will the housing kits come with axles or will axles be a seperate purchase.
i know the 3rd member isnt included and its a seperate purchase.
Old 05-05-2008, 07:54 PM
markd's Avatar
markd markd is offline
Frank:
I just want to confirm the dimensions before I order my g-bar and FAB 9 housing. I have a 69 Camaro with DSE mini tubs and thinking about going with a 55” rear, 5.5" backspace on an 11" wheel and 13” Wilwood disk breaks. Will this work?
Thanks - Mark
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
Old 05-05-2008, 08:59 PM
Your very close. Call me tomorrow and we can figure out tire size and final width.
four zero seven 832 1752
Frank Serafine
Old 05-16-2008, 10:51 AM
68TINCAN 68TINCAN is offline
Frank,
What is the expected turn around time for ordering? I am interested in the G billet with splined sway bar. I am 4 to 6 weeks from installing a rear suspension. If i order now, will i have to wait longer?
Thank,
Jim
Old 05-16-2008, 05:33 PM
4 to 6 weeks is right in line with when we HOPE to have these.
Frank Serafine
