Old 04-24-2008, 08:16 PM
surreyboy
Guest
Posts: n/a
Default Clutch help
running a brand new centerforce dual friction, and in second gear as soon as the car sees boost at about 3700rpm it instantly spins the clutch to 6000+. its a 3300 pound car that makes about 600hp and 650 ft lbs, i checked the clutch for oil and its ok.Who makes a good clutch that can handle the power? ive had a dfx centerforce before but didnt like how little pedal feel it had, anyone have any experience with fidanza 4.3 etc? i want to stay away from twin disc set ups. the odd thing is on the dyno it didnt slip at all.
Old 04-27-2008, 11:19 AM
67ragtp 67ragtp is offline
This is a sore subject with a lot of centerforce dual friction believers(dont get me wrong they have a decent product line, its up to you to pick the right one). I had one in a 650 ftlb first gen, a solid 3500lb car with me in it. The fact is at that power level its marginal at best, I smoked it in 6 passes with hoosier QTPs, the car never dead hooked was running mid 1.8 60 footers. You probably would be better off with there LMC series, I believe it has light metal pucs on both sides of the disc and Ive heard its not too grabby. Im currently using the series 800 from Mcleod and like it, but Im no where near 650 ftlbs, made 480ft lbs to the rear wheels. I would give Mcleod a call, Im sure Red can hook you up with something nice to hold it engaged. Rich
