Old 04-25-2008, 01:39 AM
chicane's Avatar
chicane chicane is offline
Default Engine Top End, GM 12bolt Assembly and other GENI Parts
Gen I small block components:
TFS cylinder heads. New in box, 195cc / 64cc CNC chambers. For more information on this cylinder head: http://www.trickflow.com/partdetail.asp?part=TFS%2D3042B002%2DCNC&autoview= sku
$700... ($859 thru Summit)
Also have Jesel shaft rockers for the TFS cylinder heads. For more information on these: http://www.jeselonline.com/v2/index.php?categoryid=14
$695
GM Performance valve covers, with B&B breather tubes, ARP stainless valvecover stud kit and K&N open element breathers. Picture of components: http://www.geocities.com/tholt67/valvecover.html
$250
GM 12bolt differential assembly. Case number 3894860N, J196 code, October 19th 1966. This is out of my original L30/M20 chassis (that I still own) PC 1024G, October 24 Detroit. Professionally built, by me obviously... and it is currently loaded with OEM 3.55 gears and a tuned Eaton small window posi. I will even throw in a new Timken bearing set with axle bearings and seals if you ever have a need to re-build it. (I also have a NIB USGear 3.42 gear set available). Pictures coming soon.
$2000 /OBO
Slightly used but very sought after, early 7532 Weiand Team-G intake manifold. Excellent condition, carb pad has been blended.
SOLD
CV Products 1080LT road race oil pan with pick up... new and only used for mock up. Fits the 67-69 F and 68-74 X frames. This pan does not hang below the front K member and steering fitment is perfect.
SOLD
Edelbrock, Super Victor Jr. 2925, with blended carb pad and Petersen H20 bypass already mounted.
SOLD
CV Products front drive system with Edelebrock Victor water pump, Delphi power steering pump and a GM Delco three lug 105amp altenator. Pulleys, brackets and hardware.
SOLD
CV Products CNC'd two piece timing cover that goes with the above system.
SOLD
Old 05-12-2008, 03:59 PM
chicane's Avatar
Update...
