Old 04-28-2008, 05:42 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default Aftermarket Gears For a Borg Warner 9-Bolt?
Hey guys,
My brother has a 90 camaro with the Borg Warner 9-bolt rear end. He is in the need for a new ring/pinion for it, but aftermarket parts are extremely hard to find for these differentials. Does anybody know who may make a set of gears (any ratio), or other aftermarket parts like carriers, posis or rebuild kits for the 9-bolt? Any info is greatly appreciated
Old 05-01-2008, 10:03 PM
chicane's Avatar
chicane chicane is offline
Call Mark at ProGear... he'll give you the scoop on what is and is not available.
858-571-1158
Old 05-12-2008, 03:01 AM
try http://www.hawksthirdgenparts.com/in...OD&ProdID=1252
and http://www.hawksthirdgenparts.com/in...OD&ProdID=1674
Old 05-12-2008, 09:07 AM
70TWO NOVA's Avatar
Thanks! that diff cover is nice!
Old 05-12-2008, 04:45 PM
chicane's Avatar
Originally Posted by 70TWO NOVA View Post
That diff cover is nice!
Yeah... except for the fact that it does nothing... but take $149 out of your pocket.
Old 05-12-2008, 05:13 PM
70TWO NOVA's Avatar
It has the studs to pre-load the caps though, i heard that helped deflection under hard loads/launches.
