Old 08-03-2005, 02:23 PM
Nutsy Nutsy is offline
Default Can i use this to mock install my T-56??
Just wanted to know if the C5 T56 casing is the same as a LS1 T56 casing for mock up purposes?
I am wanting to install my DSE weld in cross member and i would like to have the engine/tranny mocked up to make sure i hack the floors in the right spot for both the crossmember and the shifter hole.
I already have a dummy LS1 block, but need a t56 tranny for mock up. I found this on ebay.
http://cgi.ebay.com/ebaymotors/T56-6...91013780QQrdZ1
Provided i get a bellhousing, will this work for what i want?
Any other suggestions? I just don't want to go buy a full blown T56 and have it sit for a year or two while i finish up the body/suspension work on the car.
Trev
