Old 05-09-2008, 11:16 PM
Travis77's Avatar
Travis77 Travis77 is offline
Default Sherwin Williams automotive products???
Who all have used Sherwin Williams paint, primers, sealers, or coatings products for their cars? I have the opportunity to get 40% off of everything in the store. I will more than likely be taking advantage of this discount. You do not hear much about them so I thought I might ask.
67 Fastback 418, hogans upper, FAST efi, Richmond 6spd, global west front, homebrew 3-link, mini tubbed, baer brakes with hydroboost, pilot sports on Ze Boost wheels
Old 05-10-2008, 04:34 AM
Excellent stuff. Been using it since 1987. You will find some painters that are pretty passionate about their paint brands, but at the end of the day most all the big names are good stuff and very similar.
Frank Serafine
Old 05-10-2008, 06:48 AM
IMHO The European brands are light years ahead on the domestic brands. The cost is a little higher, but the quality and coverage far exceed the cost difference.
Jeff Allen
J2 Speed and Custom
Old 05-10-2008, 10:26 AM
Travis77's Avatar
Prodigy, do you guys also use their primers and sealers?
Old 05-10-2008, 04:37 PM
I have used S and W primers and they are good. The ultra fill primer is good stuff, I just have something else I am using that I like a little better and it goes with the Polyester filler I use, and it cost a bit less, but you probably cannot buy it. I do not use sealers, so I cannot comment.
Once in a while we get a cutomer that insist on a particular brad. We used all ultra expensive Glasuirt 450 line on the Vette and it was nice stuff, double the money, exactly double, and in the end no better, but also very good. I actuallt did not like it for two tones as it printed badly well past the recomended tape time. The Ultra 7 base covers as good as any brand, and the clear works as good any.
Frank Serafine
Old 05-10-2008, 11:42 PM
Travis77's Avatar
Thanks. I may have to PM you later with more specifics when painting time comes. Of course, if that's cool with you.
Old 05-11-2008, 06:27 AM
Your welcome to write anytime.
Frank Serafine
Old 05-11-2008, 10:29 AM
OTE Design & Fabrication OTE Design & Fabrication is offline
Supporting Vendor
Well put Frank.
Most painters stick to what they get used to, and to them that becomes the "best paint".
