Old 05-12-2008, 10:29 AM
akrapovic's Avatar
akrapovic akrapovic is offline
Default HELP!! Disc brake conversion
I'm looking for a parts list of what i will need to convert my disc/drum setup to a modern c4/c5 corvette disc/disc setup.
I'm attempting to do this on the cheap and would appreciate any help you can provide. The only think I know of that is particular about my application is that I have a ford nine inch housing with ford "big ends."
Old 05-12-2008, 04:53 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
i found this site helpful when i was looking for info. see if it helps u out.
http://www.pozziracing.com/12_corvet...es_on_fgen.htm
Charles
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 05-13-2008, 07:29 AM
Apogee Apogee is offline
There are two common Ford Big-Bearing housings, the old style and the new style (Torino). The old style uses 1/2" T-bolts and has a 2.375 x 3.500 pattern with a 2.36" brake offset dimension. The new "Torino" style uses 3/8" T-bolts and has a 2.000 x 3.563 pattern with a 2.50" brake offset dimension.
Good luck,
Tobin
KORE3
