Old 05-12-2008, 08:07 PM
fatboyzkustoms fatboyzkustoms is offline
Default 19/20 combo on 79 bird
i am looking to buy foose speedster wheels and was wondering if anyone could give me a suggestion on tire size and what backspacing/offset i should run, i am looking at a 245 35 19 and a 265 35 19, i would like to keep the sidewall about the same height. i am also lowering my car 2.5-3" inches in the front and 1.5" in the rear.
thanks for your help
alicia
Old 05-13-2008, 02:58 AM
I would do a 8 with a 4.5 BS up front and a 9.5 with a 5.5 BS on the rear.
Frank Serafine
Old 05-13-2008, 01:58 PM
that would be fine with the tire size i'm going to run
thanks again
alicia
Old 05-20-2008, 10:06 PM
radback radback is offline
I just fitted my 79 T/A with 20" X8.5 rims with 5"BS
Perfect fit.
Old 05-21-2008, 02:27 PM
did you do 20's all the way around? what size tire did you run?
alicia
Old 05-22-2008, 05:11 AM
Yes.
20 all around.
Front 255/35/20
Rear 255/45/20
Rear tires are 29" tall, so if you put regular 27" (like my front) you can go larger)
Old 05-27-2008, 07:15 PM
what offset are your wheels, did you lower your car at all.
thanks
alicia
