Old 05-27-2008, 12:25 PM
TopEndeR TopEndeR is offline
Default FS: 383ci SBC 500+hp engine
Jan-Cen Motorsports 383 ci. By Mike Janis - Like new. approx 2000 miles
4 bolt GM block, two piece rear seal
Zero decked block, machined for rod clearance
Lunati Pro Mod series forged rotating assembly:
Lunati Pro Mod Series Forged Crank
Lunati Pro Mod Series Forged Flat Top Pistons
Lunati Pro Mod Series Forged Rods
Comp Cams Solid Roller XR292R (292/297, 254/260, .582/.588)
Air Flow Research 210cc heads, full competition race port (2.08/1.60 valves, 64cc) 10.5:1 compression
Comp Cams Lifters 888-16
Crane Cams Gold Series race rocker arms 1.6’s
Manley Pushrods 7.900
Crane Cams Pro Billet Timing Set
Edelbrock Victor Jr. intake manifold
Edelbrock Victor Jr. water pump
1inch carb spacer
Moroso 6qt oil pan
55HV oil pump and pickup
MSD Pro Billet Distributer
MSD 8.5 wires
NGK plugs
I have the dyno sheets, 93 octane, 35 degrees timing. 544.7hp @ 6400rpm, 492.8 ft.lbs @ 4900rpm. ( Using a mighty demon 750cfm with 77-85 jets.)
(Carb not included)
$5500 o/b
Phone number: 716-206-4142
