Originally Posted by jannes_z-28
I ound the numbers for you Joni,
Clutch main cylinder and rod #12565144
Clutch slave cylinder #15046288
I didn't find the filter but you can look yourself.
GM parts direct will show you the partnumbers when you checkout.
Jan
Thanks Jan!!!
The filter/regulator:
I just found in the pro-touring com at Z06/LS7 vettes dont have serviceable fuel filter ?? Could it be so ? Because i would like to use as much oem parts as possible. But i guess i can just put aftermarket regulator and filter just front of the tank and run single line up to the front.
Then the LSx Fbody clutch actuating combo ..
I check those part numbers here locally. I dont want modified kit like ats sells . If it brakes "middle of the nowhere" i have better change to get stock replacement part than custom. Besides it worked really good in my vette-i just dont understand why i lost the part numbers of it..
Then more mystery. In P-T.com forum member told it sell event the hose part separetly,wich i found really hard to believe,because they are pre filled with fluids too. I wonder what is all behind this. I allso got different Master cylinder part number:
2002 Camaro LS motor 6-speed :
Clutch Master Cylinder pn-12570277 ( $144.00 plus freight )
Clutch Slave Cylinder pn-15046288 ( $123.00 plus freight )
These do not come as a combo.
Available separately.
The line doesn't come with them either."
Howcome this( too ) can be so difficult
