Old 08-09-2005, 09:46 AM
moneypit moneypit is offline
Default Help with 4 Wheel Disk e-brake cable??
Can someone provide me with a contact for a "custom" intermediate e-brake cable for a '69 camaro with 12 bolt? I installed a rear disk brake set-up from vette brakes which has been sitting around for a while.. The instructions do not provide any info about the intermediate cable needing replaced. Any ideas? Thanks!
Old 08-12-2005, 08:18 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Default Call Lokar
If you call Lokar, they should be able to help you out. I just installed one of their cable kits on a 69 Camaro w/rear discs and it worked perfect.
Hope this helps,
Kurt
www.autokraft.org
Old 08-13-2005, 02:16 PM
Thanks Kurt for your response! I will contact them!
