Old 06-08-2008, 07:44 PM
bartcb bartcb is offline
Default 1969 Pontiac Gto For Sale
Hi,
I am new to your website (I just signed up a couple of days ago) and I would like to show you my car. It is a 1969 Pontiac GTO that I built from the ground up. I call it "The Executioner"
I have been working on it for 2 years and I finally finished it.
It is up FOR SALE. I have pictures of the buildup.
I am asking $90,000 or best offer. I am located in Fort Jennings, Ohio.
You can reach me at 567-204-0993.
Thank You, Bart
Specs:
Engine:
505ci IA II (iron block) pump-gas Pontiac engine built by Andy Mitchell
4.35” bore / 4.25” stroke
Dyno’d 606 hp @ 5,300rpm and 641 lb/ft of torque @ 4,600 rpm
Crankshaft: Eagle 4.25” stroke with 3.25” mains
Con Rods: Manley 4340 forged steel H beam rods
Pistons: Custom J.E. forged
Rings: Total Seal
Bearings: Clevite rod & main bearings, Dura bond cam bearings
Timing Set: Comp Cams nine key way billet
Oil Pan: Canton 6-qt road race
Gaskets: SCE and Fel-Pro
ARP fasteners used throughout
March aluminum pulleys
Cooling:
4 core radiator
FlowKooler water pump
Perma-Cool High Performance Stainless Steel flex fan
Stock shroud
Camshaft:
Comp Cams hydraulic roller cam
Duration @ .050: 252 intake / 262 exhaust
Lift: .600 intake / .630” exhaust
Lobe separation: 110 degreed at 106.25
Comp Cams hydraulic roller lifters
Heads/Intake/Carb/Valvetrain:
Edelbrock 60589 aluminum Pontiac Performer RPM heads (fully ported)
Flow numbers: 312 cfm @ .600 lift / 225 cfm @ .600 lift
Combustion chamber: 72cc
Intake valves: Manley Race Series stainless 2.11”
Exhaust valves: Manley Race Series stainless 1.66”
Valve springs: Comp Cams 1.55” dual springs
Pushrods: Manley 5/15” 4130 Chrome Moly
Rocker arms: PRW aluminum roller rockers 1.5 ratio
Intake manifold: Edelbrock Victor fully ported
Carburetor: Pro-Systems 1100 cfm Dominator set up for the street
Ignition:
Mallory HyFire 6 digital ignition
MSD Pro-Billet distributor
MSD Blaster II high vibration coil
Taylor Thundervolt 50 10.4mm plug wires
Fuel System:
Original gas tank with rear sump
Edelbrock Quiet-Flo electric 160 GPH fuel pump
Quick Fuel billet fuel pressure regulator -8AN
2 RobbMC high flow fuel filters
-8AN braided steel line from tank to pump to regulator
-6AN braided steel line from regulator to carb
Exhaust system:
Doug’s 1 7/8” primaries / 3 ½” collectors ceramic coated round port headers
3” mandrel bent Flowmaster with H-pipe
Flowmaster 3” Super 44 2-chamber mufflers
Pypes stainless splitter tips
Suspension/Steering:
Air Ride Technologies GM A Body RidePro Max e2 system w/remote
Tubular upper & lower front control arms with ShockWaves shocks
Tubular upper & lower rear control arms with airsprings and standard shocks
Poly bushings throughout
Hardened stainless steel bolts
1 1/4” front sway bar / 1” rear sway bar
Boxed frame
Quick ratio steering box
Moog inner and outer tie rod ends with Edelbrock heavy duty tie rod sleeves
Grant steering wheel
Drivetrain:
Turbo 400 transmission (rebuilt heavy duty) backed by a Gear Vendors Under/Over Drive
Redneck 3,000 stall torque converter
Stainless tranny lines
GM 12-bolt rear with Yukon/Eaton Duragrip posi, 3.73 gears, 33 spline axles,
TA aluminum girdle cover, c-clip eliminators, & welded axle tubes
Brakes:
Front: Baer Track System with 13” cross-drilled & slotted rotors & 2-Piston aluminum calipers
Rear: Baer Serious Street System with 11” cross-drilled & slotted rotors & 2-Piston calipers
Stainless brakes lines front to back
Paint/Body:
DeBeer black base with House of Kolor clear (looks like glass)
Shaved drip rails
Smoothed firewall
Raptor bedliner sprayed underneath entire body and wheel wells
Stainless bolts used throughout entire car
Laser straight paint & body work by Hippy’s Body Shop in Pandora, Ohio
Wheels/Tires:
18” Foose Nitrous Classics with Nitto Extreme NT555 tires
Fronts: 18x8.5 (4.5” B/S) with 235/40’s
Rears: 18x10 (5.25” B/S) with 285/40’s
Interior:
Original stock looking black interior
Custom brushed aluminum inserts in the dash and console
Southern Air heating and air conditioning system
Classic Instruments gauges
Wiring from American Autowire Highway 22 kit
Pioneer 200W CD player, Boss Audio 200W amp, Pioneer 6.5” kick panel speakers, Triple X 600W 6x9 rear speakers
ThermalSound Direct Q-Mat sound proofing used throughout the interior
Old 06-10-2008, 08:45 AM
PT Goat's Avatar
PT Goat PT Goat is offline
Well that's a hell of a first post.
Nice goat.
Matt
1965 Pontiac GTO - Paul Spotts 421 (433) w/Tripower, RamAir, 6X Heads / TKO600 / 3.90 Safe-T-Track / Vintage AC / Baer 4-wheel Discs / AGR PS / Hotchkis Bars, Shocks, Springs / SPC & BMR Control Arms / 17&18 Intro Vistas / GY F1GSD3 Redlines / '06 GTO Seats / Comp Audio
Other Rides: '59 Vette / '64 GTO (x2) / '65 GTO / '66 GTO / '66 Vette Roadster / '02 Vette / '07 Avalanche LTZ 6.0L / '08 Suzuki GSX-R750
Old 06-10-2008, 06:08 PM
Thank You!
Old 06-10-2008, 07:28 PM
72 RS/SS 72 RS/SS is offline
That is absolutely beautiful.
Good luck with the sale.
Old 06-10-2008, 11:00 PM
Gandalf Gandalf is offline
That is by FAR the most bad-ass GTO I think I have ever seen! Sweet ride man - good luck with the sale!
G.
