Old 06-11-2008, 09:22 PM
bamadale's Avatar
bamadale bamadale is offline
Default mopar k member?
what's the best way to remove one from a donor car? i know there's 4 bolts but that's about it. it's for my son's 67 barracuda which is a 6 cyl. car and the donor car is a 69 barracuda. any tips?
Old 06-11-2008, 09:41 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Are you just takin the Kmember?? Is there a motor on the donor K?? If just the K, 4 bolts and the strut rod bolts should be it. If you take the torsion bars out, be careful since they are under tension.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 06-11-2008, 10:03 PM
bamadale's Avatar
i' basically taking the k member, the 8 1/4 rearend and whatever i can salvage on the 69 that i can use on the 67. there's no motor. there is motor mounts,trans. and headers. also i will try to use whatever can be used on the suspension.
Old 06-12-2008, 08:02 AM
viper11 viper11 is offline
don't forget the steering box is attached, some times the coupler can be a b(*%ch to seperate
torsion bar adjuster bolts must be backed out all the way (the bars can be hard to remove due to seiing in the socket
jason
