Old 06-23-2008, 08:35 PM
radrambler's Avatar
Default alternator question
this is for you tech guys
i have ls1.....im only running alternator and a/c ..
manual windows /locks....no gadgets
i dont need a heavy , stock ,large amp alternator....
question is ...WHAT COULD I USE . thats on the lighter side
im sure ill have to make my to make my brackets for mounting.
i just want to see if someone KNOWS or recommends an alt. that would be enough power to handle my basic option ride thats will work and keep the weight down, ..
radrambler
Old 06-24-2008, 07:25 AM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
Are you running an electric cooling fan??, electric fuel pump?? Total output (Amps) is only part of the issue. As with an electric cooling fan what the Alt output is at idle is also an important consideration. An elec cooling fan is doing most of it's work at low engine speeds. The late model CSI type GM alt has very good output at idle and isn't that large or heavy. IMO don't skimp on your alt. If your alt has marginal output at low speeds (AMPS) then the voltage will suffer and drastically effect the performance and life expectancy of these elec. componants. If your building your own brackets do the math on your drive ratio. The Alt normally spins faster than the engine by 3 times. Check the max operating speed of the alt with the manufacture and again do the math at engine redline and see where you are at. If you spin the alt slow at idle it will drastically effect the out put. Check with the guys at Power Master http://www.powermastermotorsports.com/tech_help.html
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 06-24-2008, 09:28 PM
radrambler's Avatar
Default ok
thanks
and yes electric dual fan kit and electric fuel pump...
ill try your recommendation
thanks
radrambler
Old 06-24-2008, 10:03 PM
monza's Avatar
monza monza is offline
Looking and reading about alternators here~
How many people with relocated batteries in the truck run the alternator wire directly back to the battery?
(sorry I guess I'm jacking your thread)
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 06-28-2008, 01:24 PM
tom0000's Avatar
tom0000 tom0000 is offline
If you are talking about your camaro, your hot wire should be going to the splice by your horn relay instead of directly to the battery. http://www.madelectrical.com/electrical-tech.shtml This site has alot of great information on the subject. That's a sweet camaro.
