Old 06-26-2008, 07:52 PM
Joel145 Joel145 is offline
Default Spot weld cutter
Can you guys chime in on a good quality set of spot weld cutters. I found these, has anyone used these before?
http://www.blairequipment.com/Spotwe...d_Cutters.html
Joel
Old 06-26-2008, 08:03 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Yes those work awesome.
Autokraft
Old 06-27-2008, 05:23 AM
redfire69's Avatar
redfire69 redfire69 is offline
I've not had good luck w/the double-ended ones at the bottom of the page. The one-piece worked better for me...
Ron
69 Camaro Redfire
Old 06-27-2008, 06:07 AM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
The premium bits are the only way to go. The double ended bits work but are delicate and fussy. spend the money and get the premium. Run them at slow speeds they will last alot longer. Also I use an 1/8 inch bit to place a pilot divot in the middle of the spot weld before using the cutter.
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 06-27-2008, 09:26 AM
That's what i was thinking. I try not cheap out on tools because more often that not one ends up paying twice. Thanks for the 1/8" bit tip. I'll be giving the premium bits a try.
Old 06-29-2008, 09:42 PM
John Larson John Larson is offline
I've got one of those double-ended cutters and I do agree on the delicate aspect. I had three teeth break off after just a handful of cuts.
Old 06-30-2008, 11:29 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
I use a single style cutter from www.hougenmfg.com called a Rotacut sheet metal cutter. I just put a dimple with a centerpunch in the middle of the weld( and sometimes do the drill thing ,too) and a few seconds later it's done. They're almost like the cutters shown on the bottom of your link. Most of the bodymen I know use the solid, drillbit style, as it doesn't leave as much metal in the center of the weld like the circular cutters do. Just a matter of preference, or experience, I guess.
RicG
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
Old 07-05-2008, 03:30 PM
deuce_454's Avatar
X2 i hate the ones in the bottom.. they always walk or loose the teeth right when they are not supposed to!
Jake: Hit it.
Old 08-17-2008, 05:37 PM
Worked like a charm. Thanks guys.
