Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 07-01-2008, 01:12 PM
ajjones44 ajjones44 is offline
Default 64-67 GM A Body Chassis
As the title says I am looking for a chassis to fit a 64-67 A-body. Preferably on the east coast. Thanks.
Old 07-02-2008, 03:57 AM
comp-spec's Avatar
Do you need everthing or just the frame
I have a 66 frame that's in perfect shape already sandblasted and primed
Old 07-02-2008, 05:02 AM
Just the frame......is it boxed?
Old 07-02-2008, 03:33 PM
comp-spec's Avatar
Stock 66 hardtop not boxed
Old 07-02-2008, 05:39 PM
ironworks's Avatar
I have 2 out back...... In California.
Rodger
Old 08-13-2008, 07:44 PM
Bad94 Bad94 is offline
Rodger
are they convertable frames?
I need a 1966 Convertable frame real bad
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 08-13-2008, 08:40 PM
COYBILT's Avatar
COYBILT COYBILT is offline
I want to give a little insight on this topic.
The chevelle frames are shorter then the GTO,El camino, Chevelle wagon, skylark, and F85/skylark chassis. the part on these frames that is longer is the the trunk section.
I have also noticed that some of the frames have two extra body mounts, there located next to the outer firewall mounts. The convertibles are boxed, as you guys know, and I believe the el caminos are too. I hope this helps you guys out.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
