Old 07-02-2008, 04:37 PM
Meter Man's Avatar
Meter Man Meter Man is offline
Supporting Vendor
Post Stack, Ltd., A Member of the Auto Meter Performance Family
As some of you may know, just about a year ago Auto Meter acquired a very prominent English data acquisition and instrument manufacturer by the name of Stack, Ltd with a strong background in professional motorsport and road racing in particular. What you may not be aware of are some of the really cool products that Stack has to offer that could be just what you were looking for in terms of instrumentation for your project. Especially if you're into track
days.
In this thread I'll be posting some product info releases about different Stack products and will be happy to answer any questions that you may have
related to the Stack brand and products.
Without further delay, let's get to the good stuff!
Kris Carlson
Media Relations Coordinator / US Sales Engineer
Auto Meter Products, Inc. / Stack, Inc.
Old 07-02-2008, 04:42 PM
Meter Man's Avatar
Supporting Vendor
Default STACK ST700 Dash Display Tachometers
STACK is proud to introduce their ST700 Dash Display Tachometers, the ultimate combination instrument for competition and street applications with limited dash space. ST700’s are available in both black and white dial variations to suit your visual preference and include low glare satin black bezels. This signature STACK Analog and Digital display technology is action-packed with features, and housed in a compact 80mm casing. STACK ST700 Dash Display Tachometers feature the legendary, extremely rugged, STACK stepper-motor movement, with Digital Quartz accuracy for unparalleled precision and is configurable for most engine types utilizing standard and magneto style ignitions. ST700’s come standard with the following features:
- Peak ‘Tell-Tale’ memory for all monitored engine parameters
- Integrated Voltmeter
- User programmable, 4 way configurable, LED sequential shift light
- Intelligent Alarm warning system and integrated light, with user programmable warning points for all monitored engine parameters
- 2 User configurable analog sensor input channels for use with optional sensors and harness (sold separately) to monitor any two of the following parameters: fuel pressure, oil pressure, oil temperature, water temperature, differential temperature, boost pressure, or air temperature to name a few!
STACK ST700’s utilize adjustable brightness, LED backlighting to reduce current draw, provide excellent nighttime visibility and exceptional vibration resistance. Off-road and open top vehicle aficionados will appreciate the ST700’s extremely durable billet aluminum casing, which is fully sealed against dust and moisture, to exacting IP67 standards. Intuitive, rotary-pushbutton menu programming, and twist-lock mil-spec professional motorsports wiring harness make installation and operation a breeze. The show crowd will also appreciate demo mode functionality, which gives life to all the functions of the display and gives the look of speed to your car’s interior even while it’s sitting still.
STACK ST700 Dash Display Tachometers are available in a variety of RPM ranges to suit your application including 8k linear, 10.5k dual scale, and 15k dual scale.
Looking for even more functionality out of your ST700 display? Select from these additional performance options and build the system to your exact specifications and requirements:
-Wheel Speed, Odometer, and Tripmeter (Standard on ST700SR, Wheel Speed ST670 Standard on ST700M) - Does your application see double duty as street vehicle and track day terror? Add options ST670 for wheel speed (Km/H or MPH) and ST7094 for Odometer and tripmeter.
-Lap Timing System (Standard on ST700M)- Track Day, Time Attack, and Club Racers will appreciate the ST700’s optional ability to connect to Infrared Lap Timing Receivers for Lap Time information displays with accuracy up to 1/100th of a second.
-Lap and Split Time Memory (Standard on ST700M) - With memory space for up to 75 laps and split times (if split timing is activated), the lap and split time memory is an extremely useful tool for drivers looking to hone their performance and increase their consistency on the track.
- Acceleration Timer (Standard on ST700SR) – This feature will record standing quarter mile times as well as acceleration and deceleration times between any user defined speeds (i.e. 0-60, 60-0, 60-100, etc.), making this an ideal feature for evaluating performance upgrades to your vehicle.
- Performance Upgrade (Standard on ST700M)– Add Split Time system, and Straight and Corner Speed readout options to your ST700 package, when you’re ready to view real time information out on the track useful for evaluating driver performance.
- Neutral Gear Indicator – With the use of the ST918050 harness, the ST700 can be connected to the Neutral position switch of any sequential gearbox.
STACK, when only the best will do!
For more information about these instruments and other quality STACK products visit www.stackinc.com or call us toll free at 1-888-867-5183.
About Stack:
Stack is a leading supplier of solutions for data acquisition in Motorsport with over 25 years of proven experience and service. Applications including data loggers, lap timers, dash displays, tachometers, instruments and gauges, analysis software, and unique harsh environment data acquisition products for all forms of motorsport.
Kris Carlson
Old 07-02-2008, 04:53 PM
camcojb camcojb is offline
I had one of their standalone dash kits, very cool stuff.
Old 07-02-2008, 11:42 PM
Blown353 Blown353 is offline
Yep, nice stuff for sure. A 0-8K blackface ST700SR is still on my "to buy" list along with the sensor harness and two pressure transducers.
1969 Chevelle
Old 07-03-2008, 01:29 PM
Meter Man's Avatar
Supporting Vendor
Thanks for the kind words guys. We're really excited about being able to work with the really talented folks at Stack, and have some really cool products in development.
Speaking of those integrated dash displays...Check out the next post!
Kris Carlson
Old 07-03-2008, 01:41 PM
Meter Man's Avatar
Supporting Vendor
Post STACK ST8130 Integrated Dash Displays for Street and Track Day Applications
STACK is proud to introduce their ST8130 Series Integrated Dash Displays. These compact instruments are perfect for competition and high performance street vehicles looking for an all business information display system. ST8130’s are available in both black and white dial variations with low glare satin black bezels to suit your visual preference. This signature STACK Analog and Digital display technology is action packed with features, and housed in STACK’s uniquely shaped lightweight carbon composite casing. All STACK ST8130 Integrated Dash Displays feature the legendary and extremely rugged, STACK stepper-motor movement, utilizing Digital Quartz accuracy for unparalleled precision and driver readability. Tachometer display is configurable for most engine types with standard or magneto style ignitions. ST8130’s come standard with the following features:
- Monitors and displays Engine RPM, Speed, Fuel Level (programmable), oil pressure, water temperature, voltmeter, odometer, and trip meter functions.
- System is supplied complete with lightweight and durable solid state sensors (except fuel level), as well as a ready wired harness.
- Shift Light Ready! For use with optional plug in single stage or multi stage sequential shift light (sold separately).
- Intelligent Alarm "plain english" warning system and integrated light, with user programmable warning points for all monitored engine parameters
- Separate Low Fuel Level Warning Light
STACK ST8130’s utilize full time, blue LED backlighting to reduce current draw, provide excellent nighttime visibility as well as exceptional vibration resistance. Off-road and open top vehicle aficionados will appreciate the ST8130’s extremely durable lightweight carbon composite casing, which is fully sealed against dust and moisture, to exacting IP67 standards. Intuitive, pushbutton menu programming and page control, and twist-lock mil-spec professional motorsports wiring harness keep installation and operation simple.
STACK ST8130 Integrated Dash Displays are available in a variety of RPM ranges to suit your application including 8k linear, 8k dual scale, 10k dual scale, and 13k dual scale.
Looking for even more functionality out of your ST8130 display? Select from these additional performance options and build the system to your exact specifications and requirements:
- Air Inlet Temperature – Add this option to monitor outside temperature, intake air, or post intercooler temperatures.
- Lap Timing System (Available Standard on ST8130M)- Track Day, Time Attack, and Club Racers will appreciate the ST8130’s optional ability to connect to Infrared Lap Timing Receivers for Lap Time information displays with accuracy up to 1/100th of a second.
- Fuel Pressure (Available on ST8130P and ST8130M) - Monitor rail pressure in addition to the above mentioned parameters on your fuel injected application when you select either the ST8130P or ST8130M. Note: units that monitor fuel pressure cannot make use of the Air Inlet Temperature option.
- Acceleration Timer (Available on ST8130M) – This feature will record standing quarter mile times as well as acceleration and deceleration times between any user defined speeds (i.e. 0-60, 60-0, 60-100, etc.), making this an ideal feature for evaluating performance upgrades to your vehicle.
- Predictive Lap Timing (Available on ST8130M)– The ultimate feature for Track Day, Time Attack and Club Racers! Predictive lap timing provides continual and instantaneous easy to read updates comparing your current lap to your recorded best allowing you to instantly see whether a setup, new line, or changed braking point has gained or lost you time on the track!
Kris Carlson
Old 08-19-2008, 06:39 PM
Meter Man's Avatar
Supporting Vendor
Default STACK 52mm Gauges
STACK is proud to introduce their proven technology in a 52mm gauge! New for 2008 STACK has introduced a line of minor instruments to complement the famous STACK tachometers and Integrated Dash Displays. Available in three movement types, professional stepper motor analogue, electric analogue, and mechanical analogue to suit your performance needs and budget. All instruments feature no glare black dials and bezels with high contrast, easy to read white markings. Vivid white LED backlighting and illuminated needles reduce current draw, provide excellent vibration resistance and exceptional nighttime visibility. 32 instruments are available in the initial release with scales available in both Imperial and Metric. Series highlights include 270º sweep user programmable Fuel Level gauge and Wideband Lambda Gauge with 0-4v output for data acquisition unit or ECU.
Kris Carlson
Old 08-21-2008, 08:27 AM
syborg tt's Avatar
me likey - looks like what i may be using these on the next project.
marty-mj
Old 08-31-2008, 01:55 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Kris:
Glad to see you here. You didn't tell me Auto Meter had Purchased Stack. Is the Autometer website been updated yet, or will they remain separate entities?
I bet you'll be a busy guy here, from looking around I really like the technology Stack Brings to the gauges, and the Data/Video logging options.
I look forward to more updates, and thanks for working with me via email. I'm sure we will be visiting again soon.
Good Luck,
Ty O'Neal
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 09-02-2008, 02:56 PM
Meter Man's Avatar
Supporting Vendor
Marty-
Happy to discuss and answer any questions when you get ready to start on your next project.
Ty-
Auto Meter acquired Stack in July of 2007. We have joint projects in the works and the Auto Meter website has been updated to include a link to the Stack website. Stack is now part of the Auto Meter performance family, but is a strong brand in its own right and will remain its own separate entity. As always, happy to assist with any questions you or any of the others reading this may have related to their projects.
Kris Carlson
