Old 07-06-2008, 12:30 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Default Mild 350 SBC Engine
I have a relatively mild 350 SBC for sale - 0.030 over, 010 block; Vortec heads with cleaned up chambers, screw in studs and aftermarket springs good to 0.550 lift; Pro Magnum 1.6 self-aligning roller rockers; Comp Cams pushrods; Comp Cams XE-268 hydraulic cam; 650 CFM Demon Carburetor with electric choke; MSD distributor; Edelbrock Performer Air Gap intake manifold; billet aluminum spark plug wire looms; chrome valve covers; aluminmum timing cover. Approximately 10:1 compression ratio with about 12,000 miles on it since it was built. It'll need a harmonic balancer, as I reused the one that was on it. FWIW, Desktop Dyno says about 360 hp. $1,800 OBO - I need this thing gone. Local pickup in Southern California. The engine is in Altadena, California.
Old 09-19-2008, 04:52 PM
dstryr dstryr is offline
Did you ever sell this? Willing to part it out at all?
