Old 07-14-2008, 05:28 PM
Modmach1's Avatar
Modmach1 Modmach1 is offline
Default Help with 14" Wilwood Brakes on Mustang
Well, its time to step my Mustang up a notch!
I have a 73/71 Mustang Mach-1 (Phat-1) and now its time for some big brakes to fill my 18" and 20" combo.
I have a full front 14" brake kit from Wilwood with the Superlite 6 Big Brake hub kit for Prospindle with 14.00" diameter vented rotor.
The spindles are 2" drop prospindle Kit pn 830-9807 and is meant for a 69 Mach-1 with Mustang II frontend.
Well here it goes, i have original spindles and frontend on my Mustang.
What can i do to make this fit ? I have yet to find someone that makes other spindles for the 71-73.
Can i just use the original spindles?
The kit is bought from Prodigy Custom
Hope someone here can help me
GP Super Store has put together fantastic brake packages using Wilwood products and other products we distribute to have the most complete brake systems at killer deals. Complete packages including complete front kits, complete internal e brake rear kits, E brake cables, Braided hoses, Proportioning valves and Master cylinder in 12", 13" and 14" set ups are available for most popular muscle car applications. Prices start as low as $1650 for complete 12" F and 12" R Wilwood street set ups. BIG NEWS, We also have rear internal e bakes sets for popular muscle car applications in both 13" and 14" with internal e brakes using lightweight aluminum hat / steel rotors with SUPERLITE calipers. Combined with huge matching 13" and 14" fronts, we guarantee the most bling / bang for the buck in the brake industry. Killer brakes at nearly half the cost of other big brake companies.
1973 Mustang Mach-1 "Phat-1"
1964 Chevrolet Bel Air Stw "BeLow"
1968 Plymouth Barracuda
Check out my site www.Moldestuket.com
Old 07-14-2008, 06:40 PM
Back when we ordered you were switching to Mustang 2 components. That is the first Pro Spindle set up on the planet. Has the plan to use Mustang 2 stuff changed?
I do not know of any replacement 71-73 spindles. Have you measured to see if the Mustang 2 stuff you got is the same or close? I doubt the Hubs would fit your original or replacment spindles as they are designed to fit those Pro Spindles (which are Mustang 2 stuff).
Let me know
Frank Serafine
Old 07-14-2008, 10:44 PM
Modmach1's Avatar
Hi there
Im actually a buddy of the guy who bought the parts from you, and he has plans on Mustang II stuff..
Changes has been made on his project so i can now buy them from him.
I havent measured it yet though, but my brother said something about that the original ones are missing the caliper bracket place to screw them on
Old 07-15-2008, 03:54 PM
Modmach1's Avatar
The rear set is the 140-10012 with big bearing Ford, new style.
What will the new style means? witch ford rearends are that?
Old 07-15-2008, 07:40 PM
OK, that explains it.
As for the NEW style Ford, that is what is called the "Torino" end.
Here are the different end housing measurements.
Frank Serafine
Old 07-15-2008, 10:32 PM
Modmach1's Avatar
And i have a original 73 9" rearend, so then the rear brakes wont fit`?
Old 07-16-2008, 03:38 AM
You need to measure the pattern on the axle end bolt pattern.
Frank Serafine
