Old 07-24-2008, 09:24 AM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Twin Turbo LS1
Can a stock TT LS1 support approximately 550rwhp?
Chris
Old 07-27-2008, 06:13 PM
camcojb camcojb is offline
I've seen several make that much power. That is at the upper limit however with a stock engine.
Old 07-27-2008, 07:00 PM
Blown353 Blown353 is offline
...and even at that power level I'd be slightly worried about the possibility of pinching a ring with stock ring end gaps.
1969 Chevelle
Old 07-27-2008, 07:05 PM
WILWAXU WILWAXU is offline
I seen them support nearly that much Naturally Aspirated
Trick is the tuning. If it rattles, #7 will take a dump on you.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 07-29-2008, 04:35 AM
Mike Norris Mike Norris is offline
Supporting Vendor
As mentioned a lot has to do with tuning. I have a few 550 RWHP SC and TT cars out there running well on stock engines. Get to the 575 area and it seems I run into the ringland breaking between the top and second ring.
Now keep in mind that most of these cars are drivers with occasional WOT on the street or track. If you are a hard driver a lot of the time, then you can expect issues such as pinched rings and burnt pistons at the 550 level from what I have seen.
I would also install a good set of valve springs on a stock LS to be safe.
Hope this helps.
Mike Norris
Mike Norris Motorsports
Raymonds Performance
3828 Clarks Creek Road
Plainfield, IN 46168
407-616-2518
www.mikenorrismotorsports.com
[email protected]
Visit Our Facebook Page
Old 05-18-2009, 07:55 PM
nightrunner nightrunner is offline
yes it can take that much power but like said if its driven really hard all the time, might want to back it down to say 500rwhp. i would definetely add valve springs to a boosted LS1. make sure your tuning is right and you have enough fuel for the amount of boost you will run.
Old 06-02-2009, 08:37 PM
gearheadgarage's Avatar
gearheadgarage gearheadgarage is offline
Don't forget that big boost combined with factory high compression will eat up bearings if driven hard and often. I just smoked my bottom end after 12k miles on my 520rwhp MagnaCharged LS2.......I'm PISSED!!!
Old 06-02-2009, 11:39 PM
Flash68's Avatar
Flash68 Flash68 is offline
Dude that sucks!!!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 06-03-2009, 05:26 AM
manny z manny z is offline
Default engine
A top of what was mentioned by jason, make sure your AFR's are on the nose. I have done a lot of work on turbo srt-4's an I really push the AFR subject wehn they wanted to add more boost, or bigger turbos.
With the stock bottom ends of all modern engine being built with tighter tolerances, you have to be really carefull about beating them up to much with keeping your stock high compression.
One thing you could do is, change the cam that will have a little more over lap. Or get some head gaskets that will lower you comp by a point.
There is much more you can do without going to far in the eingine to make live at the HP level you want.
Jason, you know what it means when this happens right? Now you have an excuss to build something with more power.
Old 06-05-2009, 02:42 PM
YUP!! I tried to cheat it by using thicker head gaskets and a cam with more overlap to effectively reduce dynamic compression.....
Guess I might have to get a stroker kit: crank, rods, dished pistons and then run more boost? OH NO, maybe I am gonna have to have a little more giddyup under the hood now?
Reccomendations anyone???
