Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 07-29-2008, 05:49 PM
pitstain pitstain is offline
Default 3-link, Airride Gen2 Lightning build.
Well here is the progress so far on my life wrecking, psychosis inducing buildup of my 2002 SVT Lightning.
Bed off and all the hangers cut off, shocks and leafs removed....what a PITA
Ahh fabrication fuel....
leftovers anyone?
Old 07-29-2008, 05:50 PM
Temporary home for the bed.
Starting to clean up some of the rear frame.
The start of the plates for the 2 lower arm frame mounts.
Lower arm axle mounts coming together
Old 07-29-2008, 05:51 PM
Frame mounts mocked up, these will get fully boxed and bolted down with 5 5/8" grade 8 bolts.
Made a plate which bolts to the front hitch holes to hold the 5 gallon airtank and the pair of compressors. And if I ever need to I can still mount up the trailer hitch.
Old 07-29-2008, 05:53 PM
To the right are the rear upper shock mounts I made, next to the ones my buddies in Canada sent me.
Talk about A damm complicated bracket to build, this is the thrid link bracket, which will bolt to the crossmember over the gas tanks on the passenger side.
Started stripping and prepping the rear axel.
The crossmember for the watts link coming together, it was rather tricky because the framerails get closer to eachother the farther back you go on the frame.
Old 07-29-2008, 05:54 PM
The rest of the watts link buildup.
Old 07-29-2008, 05:55 PM
The watts link cross member and the two from lower arm mounts all painted up.
Lower and upper link mounts are on the rear axle!!
Little hackery on the frame for the teenie tiny notches I will be making.
Old 07-29-2008, 05:56 PM
Front frame mounts bolted on, and with 5/8" grade 8 all the way...and they tie into my Kenny Brown X-factor.
Old 07-29-2008, 05:57 PM
Tube for one of the link bars, cut to length and drilled for plug welds, threaded inserts moked up, and a finished and painted link bar.
The watts linkage, just need to build the clamp on axle tube mounts next week.
Some of the prep done to the airlines to armour them up, all airlines covered in techflex braided sleeve and fully wrapped in 3M super 88 electrical tape.
Gave a little love to the axles with some paint.
