Old 07-31-2008, 05:30 PM
10Seconds's Avatar
10Seconds 10Seconds is offline
Default Do all GM t-56's have a 1 1/8 input shaft?
Well, do they? If not all, which ones do?
Old 09-17-2008, 01:55 PM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
The only T-56 that does not have a 1-1/8 x 26 spline shaft is from a 2000 Mustang Cobra R and the 2003-04 Mustang Cobra. Both have the 1-1/16 x 10spline shafts. I beleive the Tremec aftermarket 011 box's also give you the option of either 10 or 26 spline shafts.
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
