Old 08-08-2008, 12:43 PM
455T/Akid's Avatar
455T/Akid 455T/Akid is offline
Default 2nd gen F-Body suspension
What do yall think is the best suspension out there for my 79 TA. I want it to handle comfortably like a modern day sports car. What do yall suggest
Old 08-08-2008, 01:36 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Wow - you have tons of options. These are just a few of my views on them. All will be very capable on the road and the course.
Air Ride - Street Challenge setup
http://www.ridetech.com/catalog/Stre...tems-23-1.html
-very adjustable
-coolness factor of the park it and slam it option
uses the stock front subframe with a taller spindle for better geometry (camber gain).
DSE Quadralink and Subframe
http://detroitspeed.com/productpages/product_page.htm
-very well engineered
-detailed installation instructions (DVD video if you want)
-can fit big meats up front and in the rear w/ the mini-tub
AME Subframe - I think they are working on the rear setup.
http://artmorrison.com/layout.php?y=...amaro/&x=index
very comparable to the DSE front - this one is mandrel bent tubing vs. the DSE hydroformed rail. It's more of a fabbed look vs. an OEM look. AME uses C5/C6 upper/lower control arms as well as upright. DSE utilizes their own control arms with the C5/C6 upright.
Lateral Dynamics - 3 link rear w/ watts link.
http://www.lateral-dynamics.com/
From a design standpoint the 3 link is superior. Many discussion have been had on this forum and others comparing this setup to others - mainly the Quadra-link. I haven't been exposed to too many people with this setup. It isn't being widely used yet to my knowledge, partially due to its "newness"
SC&C front setup w/ ATS spindle (stock subframe)
http://scandc.com/products.htm
I really like the ATS spindle setup from the standpoint that you get the opportunity to utilize C5/C6 bearings and brake components and avoid the cost of an entirely new subframe. I've heard good things about Marcus and his support.
I'm sure there are other options out there. DSE also offers their upper and lower control arms and an upgraded steering box etc. for the stock subframe.
In the end, I guess as always it comes down to budget and intended purpose.
Back to your original question - "Best" is pretty vague, as they all have their advantages and disadvantages.
If I owned a 2nd gen car today and my budget permitted, I would give it the full DSE treatment. - personal preference
I know people that have had personal experiences with all of these companies with the exception of Lateral Dynamics (not necessarily good or bad, just haven't had any experience with them) The other companies are all stand-up operations with good support and products.
Hopefully my ramblings have helped in some way. The good news is that you have a ton of choices - the bad news is you have to choose. Do plenty of research and use the "Search" function on here liberally to educate yourself as much as possible. Any way you look at it you are going to spend some coin.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-08-2008, 01:59 PM
455T/Akid's Avatar
thnx! im really liking DSE or Lateral Dynamics setup; what is a mini-tub kit? is that for if you want wider tires in the rear?
patience is a virtue but I'm running out of patience!!
'79 TA project
Old 08-08-2008, 05:50 PM
wiedemab's Avatar
DSE makes factory looking inner wheelwells that are deeper - ie: allow for wider wheels and tires in the rear.
http://detroitspeed.com/productpages..._body_prod.htm
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-08-2008, 08:42 PM
frankenstang frankenstang is offline
Jeff Schwartz offers a 2nd gen F body FULL Frame now. His shop demo car should be out of the paint booth and at the shop in 2 weeks.
Please check out www.gmachinechassis.com
He is a sponsor on this site. www.schwartzperformance.com
And there is a page dedicated to the 81 twin turbo T/A he's building on the main site.
This chassis design just one the 81 and older class at the CarCraft summer nationals for Street Machine of the year.
check out pics of the car at www.fquick.com/frankenstang
Old 08-10-2008, 11:16 AM
455T/Akid's Avatar
The quadralink rear suspension kit will just fit right in with my existing leaf spring rear suspension?
'79 TA project
Old 08-10-2008, 12:51 PM
David David is offline
read the website.
here is the product you asked about
http://detroitspeed.com/productpages...uadra_prod.htm
