Old 08-09-2008, 09:27 PM
slownova slownova is offline
Default 700+ Hp Ls7
im selling for a friend...
call or email Chuck at:
Phone: 281-477-3100
[email protected]
Motor built by Erik @ HK Racing Engines
Fresh never ran, in the bag!
GM LS7 Block
GM LS7 crank, front snout milled for standard LS1-LS6 style balancer
GM LS7 Titanium rods
GM LS7 Pistons
GM LS7 Piston rings
Federal Mogal 3/4 grooved main bearings
ACL Coated rod bearings
ARP Main studs
N-Motion double roller LS2 timing chain
Comp Cam 254/260 on a 113 LSA cam .676/.680 lift
Manton Series 3 3/8 7.730 custom pushrods
Jimmy Bell ported LS7 Heads, flow 400cfm @ .650 lift
Jimmy Bell ported LS7 intake manifold (painted silver)
GM Titanium intake valves
GM Exhaust valves
.700 lift 1000 dollar valve springs w/ titanium retainers
ARP Head Bolts
I'm sure I'm missing something... Obviously this motor would cost around 16k dollars to duplicate. I am selling it for 11,800.
Old 08-09-2008, 09:47 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Wow...wish I had that kind of money to spend right now!
Curtis
Old 08-10-2008, 04:04 AM
67ragtp 67ragtp is offline
What kind of street manners do you think it will have? The cam looks large, although the lsa @113 should build some vacuum. Does it have to be set up for dry sump?
Thanks Rich
Old 08-10-2008, 09:50 AM
im sure it will have awesome street mannors! i can't really say as ive never rode in a car with that sized cam. and yes all LS7s gotta be set up with dry sumps.
Old 08-10-2008, 02:46 PM
4mm 4mm is offline
Better check that out to be sure, Chuck told me it was set up for wet sump and the crank snout milled. Has a 24 tooth reluctor.
Old 08-10-2008, 02:53 PM
Steve1968LS2's Avatar
im sure it will have awesome street manners! i can't really say as ive never rode in a car with that sized cam. and yes all LS7s gotta be set up with dry sumps.
No, LS7s can run wet sump pans now. I just built one.
Old 08-10-2008, 05:35 PM
your possibly right. i should of asked before posting. not sure why he didn't list that.
Old 08-11-2008, 05:21 AM
fesler's Avatar
fesler fesler is offline
Steve, we have one as well that a customer wanted to change over to wet and if you do the research from GM it appears you can do it with some mods. While doing your build what did you guys do? This would be a good post to start.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 08-11-2008, 05:27 PM
this is in fact a wet sump motor and its located in houston texas.
