Old 08-16-2008, 09:47 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Default LS2 dipstick with AutoKraft pan
The stock dipstick doesn't work with my oil pan, what did you guys do to modify the orignal or which one to buy?
Thanks,
Rich
67 RS/SS
Old 08-16-2008, 11:07 AM
camcojb camcojb is offline
Thanks,
Rich
I used the Lokar version for the LS1; it goes into a hole in the passenger side of the block, just above the pan rail. My block was plugged there, just removed the plug, added a small amount of silicone for the o-ring since the hole was tapped, and it seals perfect.
ED-5008
http://www.lokar.com/product-descrip...-dipsticks.htm
Old 08-16-2008, 11:28 AM
rich-allen's Avatar
Thanks for the link jody
Are you running the autoKraft pan? Did you weld up the exsisting hole in your pan?
Thanks ,
Rich
67 RS/SS
Old 08-16-2008, 01:38 PM
Thanks ,
Rich
no, I have the ATS pan. If the pan has the correct LS hole in it then a universal or the LS style Lokar should work, won't need to go through the block. If it won't fit in the pan you'll need to plug it obviously.
I'd call Kurt and see what he uses.
Old 08-18-2008, 03:53 AM
sfenco sfenco is offline
Default dip stick
I have the auto craft pan on an ls 2. I knocked out the plug in the block and stuck the factory dip stick in the hole and it sealed with the original o-ring. When the stick shows full, I believe I am a quart to high on the level. steve
Old 08-18-2008, 05:46 AM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
If it's an LS2 then just like Jody mentioned you remove the plug in the block right above the pan rail and either install a Lokar dipstick or an F-body dipstick
Autokraft
Old 08-18-2008, 06:31 AM
rich-allen's Avatar
Thanks guys,
looks like the Lokar is the one to have.
67 RS/SS
