Old 08-29-2008, 07:07 AM
el-camino's Avatar
el-camino el-camino is offline
Default Varishocks adjustment
hi,
have anyone tips for me, for a correct adjustment ?
in front of my 79 Camino i drive with coil overs from varishock.
this thing is hard, to hard
when i adjust the shock one or two clicks smarter, the car jumps around like a australian race-mouse.
one or to clicks stronger the car is to hard and i lost all my theeth
is the spring rate to high or what can i do ?
greets from Sweden
Klaus
Old 08-29-2008, 10:37 AM
FreddieCougar's Avatar
FreddieCougar FreddieCougar is offline
PM sent....
Old 08-29-2008, 03:00 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
Step #1 is to read and follow the 8 page tuning guide that came with the coil overs. Varishocks have a huge range of adjustment so there IS a happy medium setting for you. You`ll probably want to start at 6 clicks from soft for starters and go from there. Varishocks aren`t available with spring rates so high they would cause it to ride that harsh. If a setting between 5 and 7 still rides very hard then there`s likely a clearance issue elsewhere in the suspension or the spring preload is cranked up too high and the springs are coil binding making the ride harsh. Check the powder coating between the coils for signs of contact. Mark SC&C
Old 08-29-2008, 04:14 PM
el-camino's Avatar
thanks marcus, i will check this
greets from Sweden
Klaus
Old 09-01-2008, 09:16 AM
el-camino's Avatar
hi again,
for a few minutes i Check the powder coating between the coils for signs of contact.
no contact.
i check also the adjuster nut, and i can go maximum a 1/2 inch lower, then comes the end of the thread on the shock.
i will test it
greets from Sweden
Klaus
Old 09-02-2008, 04:16 AM
el-camino's Avatar
Fixed !
the Camino have now a good ride quality
the preload was too low.
i play yesterday 3 hours with the shocks, and now i have the right mix between strenght and ride quality
learning by doing
greets from Sweden
Klaus
