Old 09-04-2008, 01:04 PM
lukky 71 lukky 71 is offline
Question Rust Bullet????
New Product .has Anybody Used It And What Do You Think.im Thinking Of Use It Because Its Easy And You Can Do Body Work Over It . Dont Get Me Wrong Im Cutting Bad Rust Out This Is Mainly For The Under Side .thanx For Any Comments
Old 09-04-2008, 09:55 PM
71dusterjon 71dusterjon is offline
i bought this product in a quart to do my floor pans since there was just surface rust and i wanted some protection. i used a cheap spray gun to lay it down and it turned out good. make sure though that you scuff up everything really good with the required grit and clean all surfaces really well otherwise the rust bullet will flake off. if you have problems with it coming out of the gun evenly you could dilute it with laquer thinner, even though they say don't thin it.
