Old 09-10-2008, 10:30 AM
georgedz's Avatar
georgedz georgedz is offline
Default To narrow or not to narrow rear end
I'm doing a gen 2 f body build LS2,T56,Martz front clip w/dynalites , mini tub Fab9 and Martz 4 link. rear wheels will be 18x10, standard length of housing is 60 3/4" . should I narrow? If so how much?
Old 09-10-2008, 11:04 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Without narrowing the rear end your limited on the dish size of your rim. Big brakes also effect this rim without narrowing.
If I could turn back time I would narrow my rear.
67 RS/SS
Old 09-10-2008, 01:42 PM
LS1NOVA LS1NOVA is offline
Buy the rims you want then narrow the rear to suit. If you like deep dish, then you probably be narrowing.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 09-10-2008, 04:33 PM
lil427z's Avatar
lil427z lil427z is offline
cut it.
rick k
Old 09-10-2008, 08:10 PM
Lateral-g Moderator
Originally Posted by lil427z View Post
cut it.
rick k
I agree 100%.
Old 09-10-2008, 08:38 PM
awr68's Avatar
awr68 awr68 is offline
yep-cut it!!
Tony
'68 Camaro
Old 09-10-2008, 11:19 PM
youthpastor's Avatar
uh...i agree buy the rims, cut the axle to match
Old 09-13-2008, 02:47 AM
deuce_454's Avatar
the handling argument is that the wheel will weigh the same, regardless of offset, the rear eill weigh more the wider it is... so the shorter the rear, the less unspring weight....
also it looks cool
Jake: Hit it.
Old 09-25-2008, 04:34 PM
georgedz's Avatar
Default update
talked with Tim @chassisworks I ordered a Fab9 narrowed 4" ,now I can mini tub and go with 18x12 's and 335's.\
thanks for the help!
