Old 08-23-2005, 06:18 PM
LIL QIK LIL QIK is offline
Default Gettin Dipped
Anyone ever had there car dipped? I was contemplating getting it dipped to get a fresh start on it and knowing exactly what I have to work with. Someone advised me that I shouldn't get it dipped due to the fact that I would never get it totally sealed afterwards.
Anyone have any experience with this?
Any comment would be appreciated.
1968 Camaro SS
Twin Turbo 383
Old 08-23-2005, 06:47 PM
Lesrace82 Lesrace82 is offline
I believe they neutralize all the agents before you get the car back, but I have no first hand knowledge with it.
-Bill
1972 Camaro RS Powered by LS1/T56.
http://community.webshots.com/user/lesrace82
Old 08-23-2005, 07:15 PM
Protour_Pinto Protour_Pinto is offline
I had my car dipped. Its not the first one either.
There is a lot of prep work to do before you take it in. You have to get most of the seam sealer off with easy off oven cleaner or a propane torch. From there you have to be sure all the bolts and such are removed.
When you get it back it will be nice and clean and free of just about everything. You will have to re seal all the seams and put the sound proofing back.
If you dont want to get that involved you can have it media blasted. That will take care of all the paint stuff and rust but leaves most of the sealant.
Depending on where you live it may be possible to get it soda blasted or soda dipped. here in California its getting harder to get anything too caustic done.
Old 08-23-2005, 08:01 PM
Well the place here dips it and then afterwards they seal it for me. But they don't seal it by dipping it.........they spray it. But that's what I'm interested in. Is getting every ounce of rust off of it.......to include what I can't see.
This place didn't mention anything about getting the sealer out of the car. They said just strip it down, get all the wiring out of it, glass out and stuff like that...........and bring them the cab.
So this weekend I was going to yank the suspension out and get everything ready.........
But definitly wanted to get someone's experience on the situation.
1968 Camaro SS
Twin Turbo 383
Old 08-24-2005, 07:44 AM
trapin's Avatar
trapin trapin is offline
LIL QIK, I can give you some insight. My car was dipped and e-coated about 3 years ago. All you have to do is strip the car down to a bare shell. You shouldn't have to scrape seam sealer off or do anything else. I had mine done in Michigan and the process was that they baked the car at 600 degrees to burn off all the sealer, paint, filler, etc. Then the car was submerged for a day in the stripper. Afterwards it was taken to a facility to be e-coated. You just can't get anymore thorough then this. If you're interested, here's the contact information for them in case you want to go outside Texas to have this done.
International Paint Stripping
15300 Oakwood Drive
Romulus, MI 48174
734-942-0500
They can strip and e-coat body shells within the measurements of 13.6 feet in length and 48 inches in height. Cost: $2500
I can't say enough about it. It was WELL worth the money. And my car was a Detroit car. Today it looks like a replacement shell from General Motors SPO. See my website below for some pictures.
Hope it helps
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 08-24-2005, 04:40 PM
That's the thing that bothers me. This place that I'm talking about isn't going to e-coat it..........they're only going to phosphate coat it. And if I remember right........someone had once told me not to dip it if it's not getting e-coated.
Man..........I really like the way the car looked when you got it back from dipping.........that's exactly what I'd like to see in my garage.
1968 Camaro SS
Twin Turbo 383
Old 08-24-2005, 05:34 PM
Travis77's Avatar
Travis77 Travis77 is offline
Default dipping
I also have though about dipping, but do not know if it is worth it or not. I am also in the Houston area. Who have you talked to , if you don't mind me asking? Maybe there's a better place that I do not know about.
Old 08-24-2005, 06:04 PM
Hey Travis..........the only place I know of in the Houston area is Houston Metal Stipping and they're are actually located out in Conroe. Do you know of anyone different..........I'd be willing to take it as far as 3 maybe 4 hours away.
1968 Camaro SS
Twin Turbo 383
Old 08-29-2005, 11:02 PM
I had mine sealed after they dipped it. When it came out of the sealer tank it looked ready for paint. Not a run or a sag in site. It was the best thing I did for the project.
Here in California they can't use the bitchen stripper they use in other parts of the country. That is why I did the sealer stripping myself. The cost for the shell,fenders,doors,hood,trunk and a box of odds and ends was 1750.00 including pick up and drop off.
Old 08-30-2005, 04:15 AM
68protouring454's Avatar
Default dipping
i would not do it unless you can have car e-coated, there is no way in hell they will spray phosphate coating on all areas, especially inside rockers etc, find a e-coating place or media blast away
jake
