Old 09-13-2008, 12:45 PM
Gordz32's Avatar
Gordz32 Gordz32 is offline
Default Car hunting what can I do to fix it.
Hey everyone. So I've got about 1800 miles on the chevelle since its been on the road. The one issue I have is that driving on the california highways the car is hunting pretty bad when it finds the grooves in the concrete. I understand that the tires come into play with this, but I'm wondering if I can change anything else to help with the problem. The car has a full airride suspension, Strongarms up front, and BMR adjustables in the rear. I also installed Howe Low friction ball-joints, AGR variable ratio box with stock steering linkages. When I had the alignment done I asked them to add in some caster and a little toe in but I don't have anyspecs as to how much they added. Sometimes its down right scary, driving in LA traffic at 75mph and the car finds a groove it likes. What can I do to help this? Do new corvettes have this problem, I know they run wide staggered tires. Also will lowering the pressure in the steering box help. It seems that when the car is off, the steering box has a little play in it( Like you move the wheel and it doesn't moves the tires).
As always, any help is appreciated.
67' El Camino: 468BBC, TH400, Grocery Getter
Old 09-15-2008, 09:05 PM
Gordz32's Avatar
Bueller....Bueller....Bueller.... Anyone?
Old 09-15-2008, 09:55 PM
clill's Avatar
clill clill is offline
How is your bumpsteer ?
Old 09-22-2008, 01:31 PM
Rex Rex is offline
I really wish someone would help this guy out, because I have the exact same problem,
Old 09-23-2008, 12:10 PM
Payton King's Avatar
Default I am going to assume that all
of your ball joints, tie rods, etc are new. First thing I would do is have the alignment checked again after you call ART and get the alignment specs they reccommend for their system. Also have a 4 wheel done to make sure the rear is square in the car and with your front wheels.
What you describe is a bad bump steer problem, worn parts or bad alignment. I am assuming it is the alignment.
In my younger days, I rebuilt the front end of my 72 C10. I put the drag link on backwards (it fits both ways) It stumped me and the alignment guy for a week until I figured it out. It would behave just like you stated in your above post.
Old 09-23-2008, 02:09 PM
68protouring454's Avatar
to much toe in will do that, just go with stock aligment settings or close to it
-1.0 camber, 2-3 degrees caster, 1/16th to 1/8 toe in
Jake's Rod Shop
