Old 09-14-2008, 06:57 PM
brans72 brans72 is offline
Question trans cooler
i was wondering if you guys could give me some ideas for a trans cooler for my 1972 chevelle. specs ls1 with 4l60e trans, pics would be great i do not just wanna pick up jegs mag and order just anything if you understand where i am coming from guys. thanks brandon
Old 09-15-2008, 02:00 PM
deuce_454's Avatar
i talked to the guys at bowtieoverdrives and they actually recomended NOT using aircooled tranycoolers only, and if they were used to route the return trany fluid thru the radiator to get the fluid up to the correct temperature, and as fast as possible!!
your tranny is designed to run at engine coolant temperature, not cold like it would if you ran a trannycooler only... so unless you do alot of heavy towing and keep your tranny out of lock-up... the heat exchanger in the radiator is just fine! (just dont run the return hose/tube right next to the exhaust unshielded)
Jake: Hit it.
