Old 09-19-2008, 08:34 AM
rsk68's Avatar
rsk68 rsk68 is offline
Default need a Carb
Hi all,
Well I think i need to buy a carb that has an electric choke, the current 850 DP has had the choke plates removed and is just to much of a pain in the cold wheather, this along with some other issues its time to change. who locally in souther Cal is the carb guru that can build me a turn key unit based on my engine specs, the current one I have was tuned by JET.
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 09-19-2008, 09:40 AM
68protouring454's Avatar
no need for a choke, you just need a custom built carb. the only two places i will use is bo law, or pro systems, we used pro systems on vinnys car,496,11-1,262/266@50 cam 710 lift and his starts and runs fine even in the cold ny weather, i mean you need to blip the throttle for a min or two but there is no issues or problems.
call patrick at pro systems, you will be blown away by a custom built carb
Jake's Rod Shop
Old 09-19-2008, 02:10 PM
rsk68's Avatar
called Patrick and have ordered one Thanks.
RSK68
Rick Klein
Hood-latches.com
Old 09-19-2008, 03:34 PM
don't be afraid to call him for tuning help, on vins car we didnt turn a screw and it went 10.50 at 131, and has the best throttle reponse of any 496 out there at any rpm
Jake's Rod Shop
