Old 09-23-2008, 11:56 AM
ma73z's Avatar
ma73z ma73z is offline
Default 69 firebird thoughts
I'm am building a firebird for the wifes in our family to drive and was curious about what parts you guys would or would not recommend. The car is being built with a stock Ls1/4l60 combo. Question is do I use stock subframe or swap it, do I use aftermarket control arms and if so which ones, what brakes should I use, whos engine mounts do you like (brp, autokraft, s&p etc.) ? I've been looking at CPP stuff and was curious what you guys thought of their products (brakes, control arms etc.) I've got DSE subframe connectors and mounts but nothing else ordered. Any thoughts would be great.
Old 09-24-2008, 09:47 PM
amaronut amaronut is offline
Use all DSE stuff, pricey but worth it,,,good customer service as well..............
Old 09-25-2008, 08:17 AM
Payton King's Avatar
Default Give us some more information
Budget, how well do you want it to go, stop and turn. Look you are going for?
Old 09-25-2008, 08:37 AM
tgvettes tgvettes is offline
As it sounds like this is going to be more like a daily driver then a race car
I would stay with the stock subframe and just rebuild it with poly bushings and
Hotchkis suspension kit. ATS spindle would be a nice upgrade and then of course the car need upgraded brakes.
Tonny
Old 09-25-2008, 09:02 AM
dhutton dhutton is offline
If you are going to have air conditioning there is a case that can be made to use an Art Morrison subframe with the stock LSx accessories, oil pan and off the shelf C5 brakes to offset the cost of the subframe. This has been discussed on pro-touring.com:
http://www.pro-touring.com/forum/showthread.php?t=45932
This is the approach I took on my 69 Firebird build.
Don
