Old 09-24-2008, 09:31 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Front leaf spring perch (or whatever you call it)
So now that I got my car on the rotisserie and can have a good look at the underside, I noticed that both front leaf spring perches/mounts or what ever you want to call them have been welded in at the front. Obviously someone broke one of the bolts or the eye brackets. Do you think I'm better off leaving as is and adding more welds for extra strength and get rid of the bolts all together, or try and cut the welds and put new bolts in. I'm thinking about trying to cut the driver's side free and atleast put it straight. Here's some pics of where I mean:
Passenger side
Driver's side
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 09-24-2008, 09:47 PM
lil427z's Avatar
lil427z lil427z is offline
cut them off.
rick k
Old 09-24-2008, 11:33 PM
Cut em off and do needed repairs. There nothing as bad as leaving others bubbarepairs on the car.
63 Z06
Old 09-25-2008, 04:50 AM
torque boxes major job but they come on a full floor it you need a floor as well.
c
Old 09-25-2008, 10:02 AM
scherp69's Avatar
Thanks guys. I see Lutty's has a set for a pretty good price so I will be cutting out the old one, fixing up any holes and putting in new ones with the proper hardware. Thanks again for all the advice.
Mike
New Gen Splitters
LS3 and TKO600
