Old 09-26-2008, 03:48 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Who has built a LS3 with a Blower?
To All:
Who all has built, or knows someone who has built a LS3 with a Supercharger?
Can you tell me/us what parts they used, how large it was, type of blower, amount of boost etc?
and,
What kind of power did it make and what rpm?
Primarily interested in pump gas examples.
From what I have read, for the money, these engines are the ones to go with for a pump gas, boosted configuration.
I have been told a 416 ci is about as big you would want to go with that block. I'm not sure how far down to go down with the standard compression to make the most efficient/most HP/Most Torque, and how much Boost you could run with an inter-cooler? (Thinking about 8 psi cr, and 8-12 psi of boost if it will work properly at that level.)
I'm leaning towards the Large Eaton/Magna-Charger with the air to water inter-cooler, in large part due to the broad power band it helps develop, and it appears to be very durable for extended service.
With the new vette making 620 hp and having to meet emissions codes, I would think making 700+ hp should be fairly easy.
Does anyone have a feel how much durable hp this engine would be capable making with all forged bottom end, CNC Heads, very high quality valves, springs, retainers etc. and a really well thought out Cam Shaft, and EFI.
Any information would be very appreciated.
Thanks,
Ty
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 09-26-2008, 05:08 PM
skatinjay27's Avatar
wheels and tires section bud.
AJ
Old 09-27-2008, 01:50 AM
tyoneal's Avatar
We are in the process of building an LS3 416 with an Harrop HTV (TVS) 2300 supercharger. If you want the Eaton 4 lobe blower, then you have go Harrop. Magnacharger has no plans to sell the 2300 supercharger. I had Harrop develop a Cog drive for my blower setup. Wegner built the accessory drive for the Harrop, but we are not using their 8 rib blower pulley setup. I just received the L92 heads that have been cnc ported. The pistons are a custom piston are on order. As for horsepower, we are hoping for more than 700. Just have to wait and see.
Jeff
http://www.kodakgallery.com/67rscamaro
Jeff:
Once again, thanks for the information. You always seem to be at the forefront of all the cool stuff.
Without using the Harrop and just the Magna-Charger Product, (Which sounds like a lot less headache). What kind of results or thoughts do you have with that system?
Thanks Again.
Regards,
Ty
Has anyone else seen anything in just a Magna-Charger Configuration? (aka LS9 Clone)
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 09-27-2008, 04:53 AM
BBShark BBShark is offline
This is an supercharged LS build that looks very nicely packaged.
http://www.vettemod.com/forum/showpo...8&postcount=10
Old 09-27-2008, 08:42 AM
Pantera EFI Pantera EFI is offline
Default 2300 TVS Eaton
First, I support both Wegner & Magnuson.
I bought MY 2300 TVS from Jerry Magnuson, also the LS-92 intake, intercooler, etc.
I bought the lower blower pulley that Casey Wegner made (around the ATI dampner), Casey's water pump spacers, bolts.
The LSX block I used is stock 4.00" bore, LS-7 crank, LS-7 pan, oil pump, Crower rods with .990 pins, LS-92 heads.
I also have fitted CP "flat top" pistons.
I hope to "dyno" in two weeks.
Lance
Old 09-28-2008, 02:21 AM
tyoneal's Avatar
BBShark:
That is Modern Art I actually like.
Thanks for the link.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 09-28-2008, 05:00 AM
victionone victionone is offline
Jeff and Lance, sounds like you guys have some awesome engines cooking. How about some pictures?
Vic N
Old 10-12-2008, 10:02 AM
Default Magnuson G-8
Magnuson has released for sale the LS-3 (G-8) supercharger kit using the 2300 TVS.
I hope to post some pictures/dyno sheets before SEMA.
Lance
Old 10-16-2008, 09:12 PM
tyoneal's Avatar
Lance
That's Terrific, thanks for the update and I look forward to your pictures.
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 10-17-2008, 04:04 PM
Lateral-g Moderator
Wheel to Wheel built me one with a Harop supercharger.
