Old 10-02-2008, 02:41 PM
Rhino Rhino is offline
Default C5 cross shafts
I have a chance to pick up C5 front arms, knuckles, and hubs at what I consider to be a decent price ($500) The only problem is that it's missing the LCA cross shafts. Does anyone have a part number or pricing for these components?
Thanks in advance.
Old 10-02-2008, 03:42 PM
The reason I couldn't find them is that there is no such item. The control arms mount directly to the engine cradle, they do not use a conventional shaft.
Hopefully this saves someone some searching in the future.
Old 10-02-2008, 05:33 PM
novanutcase's Avatar
Are these parts used? If so, I would shy away. You can buy new ones at a fairly decent price and you don't have to worry about any issues you may have from the new ones!
John
Old 10-02-2008, 05:59 PM
Do you know what one should be able to find a new setup for? The cheapest I've been able to come up with so far is close to $1000.
Old 10-02-2008, 10:31 PM
ironworks's Avatar
It might be good to know what happened to the car they came off of. If it was front end accident they might be bent. The Hubs are the most expensive part of the front end.
Rodger
